[postgis-tickets] [PostGIS] #2985: server crash when analyzing small tables
trac at osgeo.org
Fri Sep 23 04:22:24 PDT 2016
Reporter: nkiraly | Owner: pramsey
Type: defect | Status: reopened
Priority: critical | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Resolution: | Keywords: analyze server crash freebsd
Comment (by ofca):
I installed 2.2.2 from ports. As to the trunk version, maybe it would be
worthwhile to ask rhurlin at gwdg.de to create some postgis-devel port?
I'll try to build 2.2.3dev and test on it, and I can give you access to
mentioned VM with premade crash databases, so you can take a look at it
yourself if time permits.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2985#comment:31>
