[postgis-tickets] r15133 - fix numeric in interpolate_from_address
Regina Obe
lr at pcorp.us
Fri Sep 23 23:31:01 PDT 2016
Author: robe
Date: 2016-09-23 23:31:01 -0700 (Fri, 23 Sep 2016)
New Revision: 15133
trunk/extras/tiger_geocoder/geocode/interpolate_from_address.sql
References #3640 for PostGIS 2.3.0 (trunk) better fix
Modified: trunk/extras/tiger_geocoder/geocode/interpolate_from_address.sql
--- trunk/extras/tiger_geocoder/geocode/interpolate_from_address.sql 2016-09-24 04:11:16 UTC (rev 15132)
+++ trunk/extras/tiger_geocoder/geocode/interpolate_from_address.sql 2016-09-24 06:31:01 UTC (rev 15133)
@@ -25,8 +25,8 @@
RETURN NULL;
END IF;
- var_addr1 := to_number(COALESCE(NULLIF(trim(in_addr1),''),'0'), '999999');
- var_addr2 := to_number(COALESCE(NULLIF(trim(in_addr2),''),'0'), '999999');
+ var_addr1 := to_number( CASE WHEN in_addr1 ~ '^[0-9]+$' THEN in_addr1 ELSE '0' END, '999999');
+ var_addr2 := to_number( CASE WHEN in_addr2 ~ '^[0-9]+$' THEN in_addr2 ELSE '0' END, '999999');
IF geometrytype(in_road) = 'LINESTRING' THEN
road := ST_Transform(in_road, utmzone(ST_StartPoint(in_road)) );
