[postgis-tickets] r15134 - ../../utils/create_spatial_ref_sys_config_dump.pl: not found on FreeBSD Add $PERL (my freebsd doesn't work without it
Regina Obe
lr at pcorp.us
Fri Sep 23 23:46:03 PDT 2016
Author: robe
Date: 2016-09-23 23:46:03 -0700 (Fri, 23 Sep 2016)
New Revision: 15134
trunk/extensions/postgis/Makefile.in
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in 2016-09-24 06:31:01 UTC (rev 15133)
+++ trunk/extensions/postgis/Makefile.in 2016-09-24 06:46:03 UTC (rev 15134)
@@ -77,7 +77,7 @@
$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
sql_bits/spatial_ref_sys_config_dump.sql: ../../spatial_ref_sys.sql ../../utils/create_spatial_ref_sys_config_dump.pl
- ../../utils/create_spatial_ref_sys_config_dump.pl $< > $@
+ $(PERL) ../../utils/create_spatial_ref_sys_config_dump.pl $< > $@
sql_bits/rtpostgis_upgrade.sql: ../../raster/rt_pg/rtpostgis_upgrade_for_extension.sql
$(PERL) -pe "s/BEGIN\;//g ; s/COMMIT\;//g; s/^(DROP .*)\;/SELECT postgis_extension_drop_if_exists('$(EXTENSION)', '\1');\n\1\;/" $< > $@
