[postgis-tickets] r15138 - Test to trap FreeBSD crash on small tables.
Regina Obe
lr at pcorp.us
Sat Sep 24 23:10:52 PDT 2016
Author: robe
Date: 2016-09-24 23:10:51 -0700 (Sat, 24 Sep 2016)
New Revision: 15138
trunk/regress/tickets.sql
trunk/regress/tickets_expected
References #2985 for PostGIS 2.3.0
Modified: trunk/regress/tickets.sql
--- trunk/regress/tickets.sql 2016-09-25 03:54:32 UTC (rev 15137)
+++ trunk/regress/tickets.sql 2016-09-25 06:10:51 UTC (rev 15138)
@@ -880,6 +880,13 @@
SELECT '#2956', st_astwkb(null,0) is null;
+-- #2965 --
+CREATE TABLE test_analyze_crash (a integer not null, g geometry);
+INSERT INTO test_analyze_crash values (1, '0102000020E6100000010000006D1092A47FF33440AD4ECD9B00334A40');
+ANALYZE test_analyze_crash;
+SELECT '#2965', ST_AsText(g) FROM test_analyze_crash;
+DROP TABLE test_analyze_crash;
-- #2996 --
WITH
input AS (SELECT 'SRID=4326;POLYGON((26426 65078,26531 65242,26075 65136,26096 65427,26426 65078))'::geometry AS geom),
Modified: trunk/regress/tickets_expected
--- trunk/regress/tickets_expected 2016-09-25 03:54:32 UTC (rev 15137)
+++ trunk/regress/tickets_expected 2016-09-25 06:10:51 UTC (rev 15138)
@@ -269,6 +269,7 @@
#2788|f|Self-intersection|POINT(1 1)
#2870|Point[GS]
#2956|t
+#2965|LINESTRING(20.9511664253809 52.3984560730436)
#2996|t
#3119a|121
#3119b|291
