[postgis-tickets] [PostGIS] #3574: Korean Manual AutoUpdate Stopped
PostGIS trac at osgeo.org
Sun Sep 25 02:26:04 PDT 2016
  Reporter:  ruvyn          |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 2.3.0
 Component:  documentation  |    Version:  trunk
Resolution:                 |   Keywords:  PostGIS 2.3.0dev Manual
Comment (by robe):
 I'm still having trouble debugging this on server.  All are giving errors
 in fact.
 po2xml ../../reference_output.xml reference_output.xml.po >
 found empty tag para
 po2xml ../../reference_processing.xml reference_processing.xml.po >
 po2xml ../../reference_raster.xml reference_raster.xml.po >
 the translation of '<refpurpose>Returns a raster or a set of geometry-
 pixelvalue pairs representing the shared portion of two rasters or the
 geometrical intersection of a vectorization of the raster and a
 geometry.</refpurpose>' doesn't start with a tag.
 ../Makefile.local:26: recipe for target 'reference_raster.xml' failed
 make[1]: *** [reference_raster.xml] Error 1
 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/docs/branches/2.3_translations/doc/po/ko_KR'
 ../Makefile.local:7: recipe for target 'local-html' failed
 make: *** [local-html] Error 2
 make: Leaving directory
 Build step 'Execute shell' marked build as failure
 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3574#comment:4>
