[postgis-tickets] r15142 - fix numeric in interpolate_from_address
Regina Obe
lr at pcorp.us
Sun Sep 25 04:41:18 PDT 2016
Author: robe
Date: 2016-09-25 04:41:17 -0700 (Sun, 25 Sep 2016)
New Revision: 15142
branches/2.2/NEWS
branches/2.2/extras/tiger_geocoder/geocode/interpolate_from_address.sql
Closes #3640 for PostGIS 2.2.3
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2016-09-25 11:36:39 UTC (rev 15141)
+++ branches/2.2/NEWS 2016-09-25 11:41:17 UTC (rev 15142)
@@ -1,5 +1,5 @@
PostGIS 2.2.3
-2016/XX/XX
+2016/09/XX
* Bug Fixes *
@@ -19,7 +19,7 @@
- #3602, perl as found by configure is not used
in tiger extension, postgis_sfcgal, address_standardizer
- #3604, pgcommon/Makefile.in orders CFLAGS leads to installed liblwgeom.h
- (Greg Troxel)
+ (Greg Troxel)
- #3607, Fix inconsistency with multilinestring in
ST_LocateBetweenElevations (Artur Zakirov)
- #3608, Fix crash passing -W UTF-8 to shp2pgsql (Matt Amos)
@@ -30,6 +30,7 @@
(Christian Quest / Dan Baston)
- #3501 use ST_Union instead of ST_Collect to compute
raster max extent constraint
+ - #3640, interpolate_from_address sometimes results in "" invalid for numeric
- #3641 tiger normalize, pagc_normalize integer out of range
- Numerous documentation corrections from ruvyn
Modified: branches/2.2/extras/tiger_geocoder/geocode/interpolate_from_address.sql
--- branches/2.2/extras/tiger_geocoder/geocode/interpolate_from_address.sql 2016-09-25 11:36:39 UTC (rev 15141)
+++ branches/2.2/extras/tiger_geocoder/geocode/interpolate_from_address.sql 2016-09-25 11:41:17 UTC (rev 15142)
@@ -7,7 +7,7 @@
-- fifth are from the other.
-- in_side Side of street -- either 'L', 'R' or if blank ignores side of road
-- in_offset_m -- number of meters offset to the side
-CREATE OR REPLACE FUNCTION interpolate_from_address(given_address INTEGER, in_addr1 VARCHAR, in_addr2 VARCHAR, in_road GEOMETRY,
+CREATE OR REPLACE FUNCTION interpolate_from_address(given_address INTEGER, in_addr1 VARCHAR, in_addr2 VARCHAR, in_road GEOMETRY,
in_side VARCHAR DEFAULT '',in_offset_m float DEFAULT 10) RETURNS GEOMETRY
AS $_$
DECLARE
@@ -24,10 +24,10 @@
IF in_road IS NULL THEN
RETURN NULL;
END IF;
- var_addr1 := to_number(in_addr1, '999999');
- var_addr2 := to_number(in_addr2, '999999');
+ var_addr1 := to_number( CASE WHEN in_addr1 ~ '^[0-9]+$' THEN in_addr1 ELSE '0' END, '999999');
+ var_addr2 := to_number( CASE WHEN in_addr2 ~ '^[0-9]+$' THEN in_addr2 ELSE '0' END, '999999');
IF geometrytype(in_road) = 'LINESTRING' THEN
road := ST_Transform(in_road, utmzone(ST_StartPoint(in_road)) );
ELSIF geometrytype(in_road) = 'MULTILINESTRING' THEN
@@ -54,18 +54,18 @@
center_pt = ST_LineInterpolatePoint(road, part);
IF in_side > '' AND in_offset_m > 0 THEN
/** Compute point the point to the in_side of the geometry **/
- /**Take into consideration non-straight so we consider azimuth
- of the 2 points that straddle the center location**/
+ /**Take into consideration non-straight so we consider azimuth
+ of the 2 points that straddle the center location**/
IF part = 0 THEN
az := ST_Azimuth (ST_StartPoint(road), ST_PointN(road,2));
ELSIF part = 1 THEN
az := ST_Azimuth (ST_PointN(road,ST_NPoints(road) - 1), ST_EndPoint(road));
- ELSE
+ ELSE
/** Find the largest nth point position that is before the center point
This will be the start of our azimuth calc **/
SELECT i INTO npos
- FROM generate_series(1,ST_NPoints(road)) As i
- WHERE part > ST_LineLocatePoint(road,ST_PointN(road,i))
+ FROM generate_series(1,ST_NPoints(road)) As i
+ WHERE part > ST_LineLocatePoint(road,ST_PointN(road,i))
ORDER BY i DESC;
IF npos < ST_NPoints(road) THEN
az := ST_Azimuth (ST_PointN(road,npos), ST_PointN(road, npos + 1));
@@ -92,7 +92,7 @@
RETURN result;
END;
$_$ LANGUAGE plpgsql IMMUTABLE COST 10;
--- needed to ban stupid warning about how we are using deprecated functions
+-- needed to ban stupid warning about how we are using deprecated functions
-- yada yada yada need this to work in 2.0 too bah
ALTER FUNCTION interpolate_from_address(integer, character varying, character varying, geometry, character varying, double precision)
SET client_min_messages='ERROR';
