[postgis-tickets] [PostGIS] #3642: winnie ticket regress error
PostGIS trac at osgeo.org
Sun Sep 25 05:03:03 PDT 2016
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.4.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 This is might wierd.  Winnie out of the blue just regressed on ticket and
 not one I changed.
 PostgreSQL 9.5.2, compiled by Visual C++ build 1800, 64-bit
   Postgis 2.3.0dev - r15140 - 2016-09-25 09:43:37
   scripts 2.3.0dev r15140
   GEOS: 3.5.0-CAPI-1.9.0 r4090
   PROJ: Rel. 4.9.1, 04 March 2015
   SFCGAL: 1.3.0
  tickets .. failed (diff expected obtained:
 /projects/postgis/tmp/2.3.0dev_pg9.5_geos3.5.0_gdal2.1.1w64/test_88_diff)
 --- tickets_expected    2016-09-25 02:12:00 -0400
 /projects/postgis/tmp/2.3.0dev_pg9.5_geos3.5.0_gdal2.1.1w64/test_88_out
 2016-09-25 05:46:59 -0400
 @@ -285,7 +285,7 @@
  #3375|GEOMETRYCOLLECTION(POINT(0 -7))
  #3399|1|1
  #3399|10|10
 -#3399|100|100
 +#3399|100|99
  #3399|1000|1000
  ERROR:  invalid KML representation
  #3437a|5
  twkb .. ok
 I'll deal with this later after release
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3642>
