[postgis-tickets] r15155 - PostGIS not building on latest OSX XCode
Regina Obe
lr at pcorp.us
Mon Sep 26 15:02:28 PDT 2016
Author: robe
Date: 2016-09-26 15:02:27 -0700 (Mon, 26 Sep 2016)
New Revision: 15155
trunk/configure.ac
Closes #3643 for PostGIS 2.4.0 (patch from pramsey)
Modified: trunk/configure.ac
--- trunk/configure.ac 2016-09-26 21:57:17 UTC (rev 15154)
+++ trunk/configure.ac 2016-09-26 22:02:27 UTC (rev 15155)
@@ -564,6 +564,20 @@
XML2_LDFLAGS=`$XML2CONFIG --libs`
XML2_CPPFLAGS=`$XML2CONFIG --cflags`
+AC_PATH_PROG([XCRUN], [xcrun])
+if test "x$XCRUN" = "x"; then
+ AC_MSG_RESULT([OSX XCode is OK])
+else
+ XCODE_VER=`$XCRUN --show-sdk-version`
+ if test $XCODE_VER = "10.12"; then
+ AC_MSG_RESULT([OSX XCode 10.12 is Not OK... hacking])
+ XML2_LDFLAGS=`$XML2CONFIG --exec-prefix=/usr --libs`
+ else
+ fi
+fi
dnl Extract the version
POSTGIS_LIBXML2_VERSION=`$XML2CONFIG --version`
