[postgis-tickets] [PostGIS] #3739: ST_Within Not using index
trac at osgeo.org
Mon Apr 24 09:53:52 PDT 2017
Reporter: postgispaul | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by postgispaul):
Wow, first: thanks for your extensive investigations!
A couple of remarks:
I (probably, only window is early tomorrow) won't be able to get
reasonable timings for the next week(s) as our server is going to be doing
some serious processing.
I thought Bitmap index scans are always worse (or at least: not better)
than normal index scans?
Still doesn't explain why the condition from the function itself isn't
taken into consideration.
Most of the time when I encounter some weird effect in our software it
pays off to dive in deep. It either leads to better understanding, or
(more often than I care of) leads to a bug/edgecase/... in some deep-
longforgotten piece of code.
That was my main motivation to file this.
I hope to get some additional timings for you tomorrow, will let yoy know
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3739#comment:15>
