[postgis-tickets] [PostGIS] #3739: ST_Within Not using index
trac at osgeo.org
Mon Apr 24 11:50:19 PDT 2017
Reporter: postgispaul | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by postgispaul):
Ok, just found some time on our server to dive into this.
The thing is: I've simplified my example to the most simple one where the
st_within isn't behaving as it should.
The initial query where I'm working with is even worse:
select ap.tags->'ISO3166-1' iso,s.admin_level admlev,s.way, s.osm_id from
planet_osm_polygon s
join planet_osm_polygon ap on ST_Within(s.way,ap.way)
where ap.tags?'ISO3166-1' AND ap.tags->'ISO3166-1' in ('KR') AND
s.admin_level ~ '^\d+$'
gives me:
Nested Loop (cost=0.28..193474644.34 rows=227104 width=271)
Output: (ap.tags -> 'ISO3166-1'::text), s.admin_level, s.way, s.osm_id
Join Filter: ((ap.way ~ s.way) AND _st_contains(ap.way, s.way))
-> Seq Scan on public.planet_osm_polygon s (cost=0.00..12924619.20
rows=513037 width=239)
Output: s.osm_id, s.highway, s.surface, s.railway, s.waterway,
s.tunnel, s.bridge, s.oneway, s.access, s.name, s.z_order, s.way_area,
s.area, s.natural, s.water, s.admin_level, s.boundary, s.landuse,
s.amenity, s.parking, s.aeroway, s.military, s (...)
Filter: (s.admin_level ~ '^\d+$'::text)
-> Materialize (cost=0.28..1479.66 rows=1328 width=258)
Output: ap.tags, ap.way
-> Index Scan using polygon_iso3166_1_idx on
public.planet_osm_polygon ap (cost=0.28..1473.02 rows=1328 width=258)
Index Cond: ((ap.tags -> 'ISO3166-1'::text) = 'KR'::text)
while
join planet_osm_polygon ap on ap.way ~ s.way and ST_Within(s.way,ap.way)
gives me
Nested Loop (cost=0.83..486830.14 rows=227 width=271)
-> Index Scan using polygon_iso3166_1_idx on public.planet_osm_polygon
Output: ap.osm_id, ap.highway, ap.surface, ap.railway,
ap.waterway, ap.tunnel, ap.bridge, ap.oneway, ap.access, ap.name,
ap.z_order, ap.way_area, ap.area, ap.natural, ap.water, ap.admin_level,
ap.boundary, ap.landuse, ap.amenity, ap.parking, ap.a (...)
-> Index Scan using planet_osm_polygon_index on
public.planet_osm_polygon s (cost=0.55..365.47 rows=1 width=239)
Index Cond: ((ap.way ~ s.way) AND (ap.way ~ s.way))
Filter: ((s.admin_level ~ '^\d+$'::text) AND _st_contains(ap.way,
s.way))
So without the extra condition, it's using a sequential scan, and that one
is definitely slower than an index scan.
Do you still need those explain analyze results?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3739#comment:16>
