[postgis-tickets] [PostGIS] #3739: ST_Within Not using index
trac at osgeo.org
Mon Apr 24 15:01:27 PDT 2017
Reporter: postgispaul | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by robe):
Yes it would help to have the explain analyze results to see what the
actual number of rows it is comparing vs what it's actually getting and
estimated vs. actual costs.
How long do each of these queries take? The slower vs. faster.
I'd also like to see the indexes you have in place, clearly the ones you
have listed above is not all of them. For example it seems odd to me that
your index cond is (ap.tags ->'....' ..) unless you have a functional
index on that. I would have also expected a gist or gin index on tags so
you could write the query like
SELECT ap.tags->'ISO3166-1' iso,s.admin_level admlev, s.way, s.osm_id
FROM planet_osm_polygon s
JOIN planet_osm_polygon ap on ST_Within(s.way,ap.way)
WHERE ap.tags @> 'ISO3166-1=>KR'::hstore AND s.admin_level ~ '^\d+$'
If you can provide some sample data that exhibits the issue that would be
really great. I know it might be hard that it might require your full
dataset so do your best.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3739#comment:17>
