[postgis-tickets] [PostGIS] #3739: ST_Within Not using index
trac at osgeo.org
Tue Apr 25 11:34:56 PDT 2017
Reporter: postgispaul | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by postgispaul):
Here are the results:
Fast one:
explain analyze
select ap.tags->'ISO3166-1' iso,s.admin_level admlev,s.way, s.osm_id from
planet_osm_polygon s
join planet_osm_polygon ap on ap.way ~ s.way and ST_Within(s.way,ap.way)
where ap.tags?'ISO3166-1' AND ap.tags->'ISO3166-1' in ('KR') AND
s.admin_level ~ '^\d+$'
Nested Loop (cost=0.83..486830.14 rows=227 width=271) (actual
time=1319.929..92007.078 rows=1377 loops=1)
-> Index Scan using polygon_iso3166_1_idx on planet_osm_polygon ap
(cost=0.28..1473.02 rows=1328 width=258) (actual time=0.067..0.076 rows=3
loops=1)
Index Cond: ((tags -> 'ISO3166-1'::text) = 'KR'::text)
-> Index Scan using planet_osm_polygon_index on planet_osm_polygon s
(cost=0.55..365.47 rows=1 width=239) (actual time=443.719..30636.884
rows=459 loops=3)
Index Cond: ((ap.way ~ way) AND (ap.way ~ way))
Filter: ((admin_level ~ '^\d+$'::text) AND _st_contains(ap.way,
way))
Rows Removed by Filter: 102799
Planning time: 0.340 ms
Execution time: 92018.858 ms
Slow one:
explain analyze
join planet_osm_polygon ap on ST_Within(s.way,ap.way)
Nested Loop (cost=0.28..193474644.34 rows=227104 width=271) (actual
time=368744.872..4795335.403 rows=1377 loops=1)
Join Filter: ((ap.way ~ s.way) AND _st_contains(ap.way, s.way))
Rows Removed by Join Filter: 1541343
-> Seq Scan on planet_osm_polygon s (cost=0.00..12924619.20
rows=513037 width=239) (actual time=26.551..4588533.670 rows=514240
loops=1)
Filter: (admin_level ~ '^\d+$'::text)
Rows Removed by Filter: 265120823
-> Materialize (cost=0.28..1479.66 rows=1328 width=258) (actual
time=0.001..0.005 rows=3 loops=514240)
ap (cost=0.28..1473.02 rows=1328 width=258) (actual time=32.366..37.253
rows=3 loops=1)
Planning time: 107.125 ms
Execution time: 4795338.151 ms
indices on planet_osm_polygon:
polygon_iso3166_1_idx : CREATE INDEX polygon_iso3166_1_idx ON
planet_osm_polygon USING btree (((tags -> 'ISO3166-1'::text))) WHERE (tags
? 'ISO3166-1'::text)
planet_osm_polygon_pkey : CREATE INDEX planet_osm_polygon_pkey ON
planet_osm_polygon USING btree (osm_id)
planet_osm_polygon_index : CREATE INDEX planet_osm_polygon_index ON
planet_osm_polygon USING gist (way)
So I used a partial index, because the ISO3166-1 tag is the only one we
use in our queries, and a full gist/gin index would be wasting too much
diskspace.
And as for sample data, that's going to take a while, if at all possible.
But if you're able to get the bitmap/normal index difference at your end,
wouldn't that be sufficient to get to the cause of the issue?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3739#comment:18>
