[postgis-tickets] [PostGIS] #2951: ST_Centroid for geography
trac at osgeo.org
Tue Aug 1 08:57:35 PDT 2017
Reporter: Mike Toews | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: liblwgeom | Version:
Resolution: | Keywords:
Comment (by robe):
Okay crash is gone, but something is not quite right about these
calculations. Seems to work okay when I do buffers, answers are as
expected.
But here is one that is glaringly wrong.
SELECT ST_AsText(ST_Centroid(geog))
FROM ST_GeogFromText('LINESTRING(-71.0846005 42.3971753,-71.0846078
42.3971502,-71.0847687 42.396707,-71.0847746 42.3966641,-71.0847638
42.3966281,-71.0847404 42.3965966,-71.0847056 42.3965679,-71.0846586
42.3965386)') As f(geog);
Output is:
POINT(-0.000955750185501768 0.00761666977447508)
note how the centroid is no where near the line. I would expect the
answer to be similar to what I get when I transform to state plane meters
to do the computation and then transform back.
SELECT
ST_AsText(ST_Transform(ST_Centroid(ST_Transform(geog::geometry,26986)),4326))
-- outputs
POINT(-71.084699611775 42.3968457764674)
I've attached screen shot.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2951#comment:11>
