[postgis-tickets] r15537 - Mark all aggregate and window functions as parallel safe, mark more regular functions parallel safe, schema qualify more missing spots
Regina Obe
lr at pcorp.us
Sun Aug 6 23:32:01 PDT 2017
Author: robe
Date: 2017-08-06 23:32:00 -0700 (Sun, 06 Aug 2017)
New Revision: 15537
trunk/postgis/postgis.sql.in
References #3751 for PostGIS 2.4 (trunk)
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2017-08-07 05:09:02 UTC (rev 15536)
+++ trunk/postgis/postgis.sql.in 2017-08-07 06:32:00 UTC (rev 15537)
@@ -420,49 +420,49 @@
CREATE OR REPLACE FUNCTION geometry_gist_distance_2d(internal,geometry,int4)
RETURNS float8
AS 'MODULE_PATHNAME' ,'gserialized_gist_distance_2d'
- LANGUAGE 'c';
+ LANGUAGE 'c' _PARALLEL;
-- Availability: 2.0.0
CREATE OR REPLACE FUNCTION geometry_gist_consistent_2d(internal,geometry,int4)
RETURNS bool
AS 'MODULE_PATHNAME' ,'gserialized_gist_consistent_2d'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_compress_2d(internal)
RETURNS internal
AS 'MODULE_PATHNAME','gserialized_gist_compress_2d'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_penalty_2d(internal,internal,internal)
RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_penalty_2d'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_picksplit_2d(internal, internal)
RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_picksplit_2d'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_union_2d(bytea, internal)
RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_union_2d'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_same_2d(geom1 geometry, geom2 geometry, internal)
RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_same_2d'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_decompress_2d(internal)
RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_decompress_2d'
- LANGUAGE 'c';
@@ -755,43 +755,43 @@
CREATE OR REPLACE FUNCTION geometry_gist_consistent_nd(internal,geometry,int4)
RETURNS bool
AS 'MODULE_PATHNAME' ,'gserialized_gist_consistent'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_compress_nd(internal)
RETURNS internal
AS 'MODULE_PATHNAME','gserialized_gist_compress'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_penalty_nd(internal,internal,internal)
RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_penalty'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_picksplit_nd(internal, internal)
RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_picksplit'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_union_nd(bytea, internal)
RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_union'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_same_nd(geometry, geometry, internal)
RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_same'
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION geometry_gist_decompress_nd(internal)
RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_decompress'
- LANGUAGE 'c';
@@ -847,7 +847,7 @@
CREATE OR REPLACE FUNCTION geometry_gist_distance_nd(internal,geometry,int4)
RETURNS float8
AS 'MODULE_PATHNAME', 'gserialized_gist_distance'
- LANGUAGE 'c';
@@ -1235,14 +1235,14 @@
CREATE OR REPLACE FUNCTION ST_IsPolygonCW(geometry)
RETURNS boolean
AS 'MODULE_PATHNAME','ST_IsPolygonCW'
- LANGUAGE 'c' IMMUTABLE STRICT
+ LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
COST 10;
-- Availability: 2.4.0
CREATE OR REPLACE FUNCTION ST_IsPolygonCCW(geometry)
RETURNS boolean
AS 'MODULE_PATHNAME','ST_IsPolygonCCW'
COST 10;
@@ -1502,7 +1502,7 @@
CREATE OR REPLACE FUNCTION postgis_noop(geometry)
RETURNS geometry
AS 'MODULE_PATHNAME', 'LWGEOM_noop'
- LANGUAGE 'c' VOLATILE STRICT
+ LANGUAGE 'c' VOLATILE STRICT _PARALLEL
COST 10;
-- Availability: 2.3.0
@@ -1740,7 +1740,7 @@
CREATE OR REPLACE FUNCTION ST_ClusterDBSCAN (geometry, eps float8, minpoints int)
RETURNS int
AS 'MODULE_PATHNAME', 'ST_ClusterDBSCAN'
- LANGUAGE 'c' IMMUTABLE STRICT WINDOW;
+ LANGUAGE 'c' IMMUTABLE STRICT WINDOW _PARALLEL;
-- Availability: 1.2.2
CREATE OR REPLACE FUNCTION ST_LineMerge(geometry)
@@ -1854,7 +1854,7 @@
CREATE OR REPLACE FUNCTION ST_Dump(geometry)
RETURNS SETOF geometry_dump
AS 'MODULE_PATHNAME', 'LWGEOM_dump'
COST 100;
@@ -1863,100 +1863,7 @@
AS 'MODULE_PATHNAME', 'LWGEOM_dump_rings'
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
--- _ST_DumpPoints()
--- Availability: 1.5.0
-CREATE OR REPLACE FUNCTION _ST_DumpPoints(the_geom geometry, cur_path integer[]) RETURNS SETOF geometry_dump AS $$
-DECLARE
- tmp geometry_dump;
- tmp2 geometry_dump;
- nb_points integer;
- nb_geom integer;
- i integer;
- j integer;
- g geometry;
-BEGIN
- -- RAISE DEBUG '%,%', cur_path, @extschema at .ST_GeometryType(the_geom);
- -- Special case collections : iterate and return the DumpPoints of the geometries
- IF (@extschema at .ST_IsCollection(the_geom)) THEN
- i = 1;
- FOR tmp2 IN SELECT (@extschema at .ST_Dump(the_geom)).* LOOP
- FOR tmp IN SELECT * FROM @extschema at ._ST_DumpPoints(tmp2.geom, cur_path || tmp2.path) LOOP
- RETURN NEXT tmp;
- END LOOP;
- i = i + 1;
- END LOOP;
- RETURN;
- END IF;
- -- Special case (POLYGON) : return the points of the rings of a polygon
- IF (@extschema at .ST_GeometryType(the_geom) = 'ST_Polygon') THEN
- FOR tmp IN SELECT * FROM @extschema at ._ST_DumpPoints(@extschema at .ST_ExteriorRing(the_geom), cur_path || ARRAY[1]) LOOP
- RETURN NEXT tmp;
- END LOOP;
- j := @extschema at .ST_NumInteriorRings(the_geom);
- FOR i IN 1..j LOOP
- FOR tmp IN SELECT * FROM @extschema at ._ST_DumpPoints(@extschema at .ST_InteriorRingN(the_geom, i), cur_path || ARRAY[i+1]) LOOP
- RETURN NEXT tmp;
- END LOOP;
- END LOOP;
- RETURN;
- END IF;
- -- Special case (TRIANGLE) : return the points of the external rings of a TRIANGLE
- IF (@extschema at .ST_GeometryType(the_geom) = 'ST_Triangle') THEN
- RETURN NEXT tmp;
- END LOOP;
- RETURN;
- END IF;
- -- Special case (POINT) : return the point
- IF (@extschema at .ST_GeometryType(the_geom) = 'ST_Point') THEN
- tmp.path = cur_path || ARRAY[1];
- tmp.geom = the_geom;
- RETURN NEXT tmp;
- RETURN;
- END IF;
- -- Use ST_NumPoints rather than ST_NPoints to have a NULL value if the_geom isn't
- -- a LINESTRING, CIRCULARSTRING.
- SELECT @extschema at .ST_NumPoints(the_geom) INTO nb_points;
- -- This should never happen
- IF (nb_points IS NULL) THEN
- RAISE EXCEPTION 'Unexpected error while dumping geometry %', @extschema at .ST_AsText(the_geom);
- END IF;
- FOR i IN 1..nb_points LOOP
- tmp.path = cur_path || ARRAY[i];
- tmp.geom := @extschema at .ST_PointN(the_geom, i);
- RETURN NEXT tmp;
- END LOOP;
-END
-$$ LANGUAGE plpgsql;
-- ST_DumpPoints()
@@ -1966,7 +1873,7 @@
CREATE OR REPLACE FUNCTION ST_DumpPoints(geometry)
AS 'MODULE_PATHNAME', 'LWGEOM_dumppoints'
COST 100;
@@ -2015,7 +1922,7 @@
gc_is_valid boolean;
BEGIN
- SELECT count(*) INTO oldcount FROM geometry_columns;
+ SELECT count(*) INTO oldcount FROM @extschema at .geometry_columns;
inserted := 0;
-- Count the number of geometry columns in all tables and views
@@ -2050,7 +1957,7 @@
AND n.nspname NOT ILIKE 'pg_temp%' AND c.relname != 'raster_columns'
LOOP
- inserted := inserted + populate_geometry_columns(gcs.oid, use_typmod);
+ inserted := inserted + @extschema at .populate_geometry_columns(gcs.oid, use_typmod);
END LOOP;
IF oldcount > inserted THEN
@@ -2333,7 +2240,7 @@
sql := 'ALTER TABLE ' ||
quote_ident(real_schema) || '.' || quote_ident(table_name)
|| ' ADD COLUMN ' || quote_ident(column_name) ||
- ' geometry(' || postgis_type_name(new_type, new_dim) || ', ' || new_srid::text || ')';
+ ' geometry(' || @extschema at .postgis_type_name(new_type, new_dim) || ', ' || new_srid::text || ')';
RAISE DEBUG '%', sql;
ELSE
@@ -2399,7 +2306,7 @@
DECLARE
ret text;
BEGIN
- SELECT AddGeometryColumn('',$1,$2,$3,$4,$5,$6,$7) into ret;
+ SELECT @extschema at .AddGeometryColumn('',$1,$2,$3,$4,$5,$6,$7) into ret;
RETURN ret;
END;
@@ -2417,7 +2324,7 @@
DECLARE
ret text;
BEGIN
- SELECT AddGeometryColumn('','',$1,$2,$3,$4,$5, $6) into ret;
+ SELECT @extschema at .AddGeometryColumn('','',$1,$2,$3,$4,$5, $6) into ret;
RETURN ret;
END;
@@ -2465,7 +2372,7 @@
-- Find out if the column is in the geometry_columns table
okay = false;
- FOR myrec IN SELECT * from geometry_columns where f_table_schema = text(real_schema) and f_table_name = table_name and f_geometry_column = column_name LOOP
+ FOR myrec IN SELECT * from @extschema at .geometry_columns where f_table_schema = text(real_schema) and f_table_name = table_name and f_geometry_column = column_name LOOP
okay := true;
END LOOP;
IF (okay <> true) THEN
@@ -2500,7 +2407,7 @@
DECLARE
ret text;
BEGIN
- SELECT DropGeometryColumn('',$1,$2,$3) into ret;
+ SELECT @extschema at .DropGeometryColumn('',$1,$2,$3) into ret;
RETURN ret;
END;
@@ -2522,7 +2429,7 @@
DECLARE
ret text;
BEGIN
- SELECT DropGeometryColumn('','',$1,$2) into ret;
+ SELECT @extschema at .DropGeometryColumn('','',$1,$2) into ret;
RETURN ret;
END;
@@ -2574,7 +2481,7 @@
CREATE OR REPLACE FUNCTION DropGeometryTable(schema_name varchar, table_name varchar) RETURNS text AS
-$$ SELECT DropGeometryTable('',$1,$2) $$
+$$ SELECT @extschema at .DropGeometryTable('',$1,$2) $$
LANGUAGE 'sql' VOLATILE STRICT;
@@ -2587,7 +2494,7 @@
CREATE OR REPLACE FUNCTION DropGeometryTable(table_name varchar) RETURNS text AS
-$$ SELECT DropGeometryTable('','',$1) $$
+$$ SELECT @extschema at .DropGeometryTable('','',$1) $$
@@ -2633,7 +2540,7 @@
-- Ensure that column_name is in geometry_columns
okay = false;
- FOR myrec IN SELECT type, coord_dimension FROM geometry_columns WHERE f_table_schema = text(real_schema) and f_table_name = table_name and f_geometry_column = column_name LOOP
+ FOR myrec IN SELECT type, coord_dimension FROM @extschema at .geometry_columns WHERE f_table_schema = text(real_schema) and f_table_name = table_name and f_geometry_column = column_name LOOP
okay := true;
END LOOP;
IF (NOT okay) THEN
@@ -2683,7 +2590,7 @@
-- We are using postgis_type_name to lookup the new name
-- (in case Paul changes his mind and flips geometry_columns to return old upper case name)
EXECUTE 'ALTER TABLE ' || quote_ident(real_schema) || '.' || quote_ident(table_name) ||
- ' ALTER COLUMN ' || quote_ident(column_name) || ' TYPE geometry(' || postgis_type_name(myrec.type, myrec.coord_dimension, true) || ', ' || new_srid::text || ') USING @extschema at .ST_SetSRID(' || quote_ident(column_name) || ',' || new_srid::text || ');' ;
+ ' ALTER COLUMN ' || quote_ident(column_name) || ' TYPE geometry(' || @extschema at .postgis_type_name(myrec.type, myrec.coord_dimension, true) || ', ' || new_srid::text || ') USING @extschema at .ST_SetSRID(' || quote_ident(column_name) || ',' || new_srid::text || ');' ;
END IF;
RETURN real_schema || '.' || table_name || '.' || column_name ||' SRID changed to ' || new_srid::text;
@@ -2702,7 +2609,7 @@
DECLARE
ret text;
BEGIN
- SELECT UpdateGeometrySRID('',$1,$2,$3,$4) into ret;
+ SELECT @extschema at .UpdateGeometrySRID('',$1,$2,$3,$4) into ret;
RETURN ret;
END;
@@ -2718,7 +2625,7 @@
DECLARE
ret text;
BEGIN
- SELECT UpdateGeometrySRID('','',$1,$2,$3) into ret;
+ SELECT @extschema at .UpdateGeometrySRID('','',$1,$2,$3) into ret;
RETURN ret;
END;
@@ -2743,7 +2650,7 @@
tabl = substr(tabl,length(schem)+2);
END IF;
- select SRID into sr from geometry_columns where (f_table_schema = schem or schem = '') and f_table_name = tabl and f_geometry_column = $3;
+ select SRID into sr from @extschema at .geometry_columns where (f_table_schema = schem or schem = '') and f_table_name = tabl and f_geometry_column = $3;
IF NOT FOUND THEN
RAISE EXCEPTION 'find_srid() - could not find the corresponding SRID - is the geometry registered in the GEOMETRY_COLUMNS table? Is there an uppercase/lowercase mismatch?';
END IF;
@@ -2759,7 +2666,7 @@
CREATE OR REPLACE FUNCTION get_proj4_from_srid(integer) RETURNS text AS
BEGIN
- RETURN proj4text::text FROM spatial_ref_sys WHERE srid= $1;
+ RETURN proj4text::text FROM @extschema at .spatial_ref_sys WHERE srid= $1;
END;
LANGUAGE 'plpgsql' IMMUTABLE STRICT _PARALLEL;
@@ -2792,20 +2699,20 @@
CREATE OR REPLACE FUNCTION ST_Transform(geom geometry, to_proj text)
RETURNS geometry AS
-'SELECT postgis_transform_geometry($1, proj4text, $2, 0)
+'SELECT @extschema at .postgis_transform_geometry($1, proj4text, $2, 0)
FROM spatial_ref_sys WHERE srid=@extschema at .ST_SRID($1);'
LANGUAGE sql IMMUTABLE STRICT _PARALLEL;
CREATE OR REPLACE FUNCTION ST_Transform(geom geometry, from_proj text, to_proj text)
RETURNS geometry AS
-'SELECT postgis_transform_geometry($1, $2, $3, 0)'
+'SELECT @extschema at .postgis_transform_geometry($1, $2, $3, 0)'
CREATE OR REPLACE FUNCTION ST_Transform(geom geometry, from_proj text, to_srid integer)
RETURNS geometry AS
-'SELECT postgis_transform_geometry($1, $2, proj4text, $3)
+'SELECT @extschema at .postgis_transform_geometry($1, $2, proj4text, $3)
FROM spatial_ref_sys WHERE srid=$3;'
@@ -3784,7 +3691,7 @@
-- Changed: 2.3.1 to support PostgreSQL 9.6 parallel safe
CREATE AGGREGATE ST_Extent(geometry) (
sfunc = ST_CombineBBox,
- stype = box3d,
+ stype = box3d,
#if POSTGIS_PGSQL_VERSION >= 96
combinefunc = ST_CombineBBox,
parallel = safe,
@@ -3868,67 +3775,70 @@
CREATE OR REPLACE FUNCTION pgis_geometry_accum_transfn(pgis_abs, geometry)
RETURNS pgis_abs
- LANGUAGE 'c';
-- Availability: 2.2
CREATE OR REPLACE FUNCTION pgis_geometry_accum_transfn(pgis_abs, geometry, float8)
RETURNS pgis_abs
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION pgis_geometry_accum_transfn(pgis_abs, geometry, float8, int)
RETURNS pgis_abs
- LANGUAGE 'c';
-- Availability: 1.4.0
CREATE OR REPLACE FUNCTION pgis_geometry_accum_finalfn(pgis_abs)
RETURNS geometry[]
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION pgis_geometry_union_finalfn(pgis_abs)
RETURNS geometry
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION pgis_geometry_collect_finalfn(pgis_abs)
RETURNS geometry
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION pgis_geometry_polygonize_finalfn(pgis_abs)
RETURNS geometry
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION pgis_geometry_clusterintersecting_finalfn(pgis_abs)
RETURNS geometry[]
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION pgis_geometry_clusterwithin_finalfn(pgis_abs)
RETURNS geometry[]
- LANGUAGE 'c';
CREATE OR REPLACE FUNCTION pgis_geometry_makeline_finalfn(pgis_abs)
RETURNS geometry
- LANGUAGE 'c';
-CREATE AGGREGATE ST_Accum (
+-- Changed: 2.4.0 marked parallel safe
+CREATE AGGREGATE ST_Accum (geometry) (
sfunc = pgis_geometry_accum_transfn,
- basetype = geometry,
stype = pgis_abs,
+#if POSTGIS_PGSQL_VERSION >= 96
+ parallel = safe,
+#endif
finalfunc = pgis_geometry_accum_finalfn
@@ -3939,49 +3849,68 @@
-CREATE AGGREGATE ST_Union (
+-- Changed 2.4.0: marked parallel safe
+CREATE AGGREGATE ST_Union (geometry) (
stype = pgis_abs,
+ parallel = safe,
+#endif
finalfunc = pgis_geometry_union_finalfn
-CREATE AGGREGATE ST_Collect (
- BASETYPE = geometry,
+CREATE AGGREGATE ST_Collect (geometry) (
SFUNC = pgis_geometry_accum_transfn,
STYPE = pgis_abs,
+ parallel = safe,
+#endif
FINALFUNC = pgis_geometry_collect_finalfn
-CREATE AGGREGATE ST_ClusterIntersecting (
+CREATE AGGREGATE ST_ClusterIntersecting (geometry) (
STYPE = pgis_abs,
+ parallel = safe,
+#endif
FINALFUNC = pgis_geometry_clusterintersecting_finalfn
CREATE AGGREGATE ST_ClusterWithin (geometry, float8) (
STYPE = pgis_abs,
+ parallel = safe,
+#endif
FINALFUNC = pgis_geometry_clusterwithin_finalfn
-CREATE AGGREGATE ST_Polygonize (
+CREATE AGGREGATE ST_Polygonize (geometry) (
STYPE = pgis_abs,
+ parallel = safe,
+#endif
FINALFUNC = pgis_geometry_polygonize_finalfn
-CREATE AGGREGATE ST_MakeLine (
+CREATE AGGREGATE ST_MakeLine (geometry) (
STYPE = pgis_abs,
+ parallel = safe,
+#endif
FINALFUNC = pgis_geometry_makeline_finalfn
@@ -4421,19 +4350,22 @@
CREATE OR REPLACE FUNCTION pgis_asmvt_transfn(internal, text, int4, text, anyelement)
RETURNS internal
AS 'MODULE_PATHNAME', 'pgis_asmvt_transfn'
- LANGUAGE c IMMUTABLE;
+ LANGUAGE c IMMUTABLE _PARALLEL;
CREATE OR REPLACE FUNCTION pgis_asmvt_finalfn(internal)
RETURNS bytea
AS 'MODULE_PATHNAME', 'pgis_asmvt_finalfn'
CREATE AGGREGATE ST_AsMVT(text, int4, text, anyelement)
sfunc = pgis_asmvt_transfn,
stype = internal,
+ parallel = safe,
+#endif
finalfunc = pgis_asmvt_finalfn
@@ -4447,7 +4379,7 @@
CREATE OR REPLACE FUNCTION postgis_libprotobuf_version()
RETURNS text
AS 'MODULE_PATHNAME','postgis_libprotobuf_version'
- LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
+ LANGUAGE 'c' IMMUTABLE STRICT;
@@ -4459,19 +4391,22 @@
CREATE OR REPLACE FUNCTION pgis_asgeobuf_transfn(internal, text, anyelement)
RETURNS internal
AS 'MODULE_PATHNAME', 'pgis_asgeobuf_transfn'
CREATE OR REPLACE FUNCTION pgis_asgeobuf_finalfn(internal)
RETURNS bytea
AS 'MODULE_PATHNAME', 'pgis_asgeobuf_finalfn'
CREATE AGGREGATE ST_AsGeobuf(text, anyelement)
sfunc = pgis_asgeobuf_transfn,
stype = internal,
+ parallel = safe,
+#endif
finalfunc = pgis_asgeobuf_finalfn
@@ -4695,7 +4630,7 @@
CREATE OR REPLACE FUNCTION ST_PointFromText(text, int4)
RETURNS geometry
AS '
- SELECT CASE WHEN geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''POINT''
+ SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1, $2)) = ''POINT''
THEN @extschema at .ST_GeomFromText($1, $2)
ELSE NULL END
@@ -4705,7 +4640,7 @@
CREATE OR REPLACE FUNCTION ST_LineFromText(text)
RETURNS geometry
AS '
- SELECT CASE WHEN geometrytype(@extschema at .ST_GeomFromText($1)) = ''LINESTRING''
+ SELECT CASE WHEN @extschema at .geometrytype(@extschema at .ST_GeomFromText($1)) = ''LINESTRING''
THEN @extschema at .ST_GeomFromText($1)
ELSE NULL END
@@ -5269,7 +5204,7 @@
AS $$
select @extschema at .ST_distance( @extschema at .geography($1), @extschema at .geography($2),false)
- LANGUAGE 'sql' IMMUTABLE STRICT
+ LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL
COST 300;
@@ -5279,7 +5214,7 @@
$$ SELECT @extschema at ._postgis_deprecate('ST_Distance_Sphere', 'ST_DistanceSphere', '2.2.0');
SELECT @extschema at .ST_DistanceSphere($1,$2);
COST 300;
@@ -5376,7 +5311,7 @@
WHERE (upper(old_name) = upper($1) OR upper(new_name) = upper($1))
AND coord_dimension = $2;
-LANGUAGE 'sql' IMMUTABLE STRICT COST 200;
+LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL COST 200;
-- Deprecation in 2.2.0
