[postgis-tickets] r15540 - update of news items
Regina Obe
lr at pcorp.us
Mon Aug 7 13:40:47 PDT 2017
Author: robe
Date: 2017-08-07 13:40:47 -0700 (Mon, 07 Aug 2017)
New Revision: 15540
trunk/NEWS
trunk/doc/reference_processing.xml
trunk/doc/xsl/postgis_aggs_mm.xml.xsl
Modified: trunk/NEWS
--- trunk/NEWS 2017-08-07 20:23:16 UTC (rev 15539)
+++ trunk/NEWS 2017-08-07 20:40:47 UTC (rev 15540)
@@ -14,6 +14,8 @@
- #3753, Gist penalty speed improvements for 2d and nd points
(Darafei Praliaskouski)
- #3677, ST_FrechetDistance (Shinichi Sugiyama)
+ - Most aggregates (raster and geometry),
+ and all stable / immutable (raster and geometry) marked as parallel safe
* Enhancements *
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2017-08-07 20:23:16 UTC (rev 15539)
+++ trunk/doc/reference_processing.xml 2017-08-07 20:40:47 UTC (rev 15540)
@@ -895,7 +895,7 @@
</para>
<para>Availability: 1.2.2?</para>
- <para>Changed: 2.4.0 added support for max-deviation and max-angle tolerance, and for symmetric output.</para>
+ <para>Enhanced: 2.4.0 added support for max-deviation and max-angle tolerance, and for symmetric output.</para>
<para>&sfs_compliant;</para>
<para>&sqlmm_compliant; SQL-MM 3: 7.1.7</para>
Modified: trunk/doc/xsl/postgis_aggs_mm.xml.xsl
--- trunk/doc/xsl/postgis_aggs_mm.xml.xsl 2017-08-07 20:23:16 UTC (rev 15539)
+++ trunk/doc/xsl/postgis_aggs_mm.xml.xsl 2017-08-07 20:40:47 UTC (rev 15540)
@@ -521,7 +521,7 @@
<xsl:if test="//para[contains(text(),'Enhanced: 2.4')]">
<para>Functions enhanced in PostGIS 2.4</para>
- <para>Most aggregates now marked as parallel safe</para>
+ <para>All aggregates now marked as parallel safe which should allow them to be used in plans that can employ parallelism.</para>
<itemizedlist>
<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment -->
<xsl:for-each select='//refentry'>
@@ -552,6 +552,41 @@
</itemizedlist>
</xsl:if>
+ <para>Functions changed in PostGIS 2.4</para>
+ <para>All PostGIS aggregates now marked as parallel safe.
+ This will force a drop and recreate of aggregates during upgrade which may fail if any user views or sql functions rely on PostGIS aggregates.</para>
+ <xsl:if test="//para[contains(text(),'Changed: 2.4')]">
+ <itemizedlist>
+ <!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment -->
+ <xsl:for-each select='//refentry'>
+ <xsl:sort select="refnamediv/refname"/>
+ <xsl:variable name='comment'>
+ <xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'
+ </xsl:variable>
+ <xsl:variable name="refid">
+ <xsl:value-of select="@id" />
+ </xsl:variable>
+ <xsl:variable name="refname">
+ <xsl:value-of select="refnamediv/refname" />
+ </xsl:variable>
+ <!-- For each section if there is note about availability in this version -->
+ <xsl:for-each select="refsection">
+ <xsl:for-each select="para | */para">
+ <xsl:choose>
+ <xsl:when test="contains(.,'Changed: 2.4')">
+ <listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="." /><xsl:text> </xsl:text> <xsl:value-of select="$comment" /></simpara></listitem>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:for-each>
+ </xsl:for-each>
+ </xsl:for-each>
+ </itemizedlist>
+ </xsl:if>
</sect2>
<sect2 id="NewFunctions_2_3">
