[postgis-tickets] r15545 - Get rid of CRLF settings on both svnprop and gitattributes. Causing mirroring issues
Regina Obe
lr at pcorp.us
Tue Aug 8 12:40:05 PDT 2017
Author: robe
Date: 2017-08-08 12:40:04 -0700 (Tue, 08 Aug 2017)
New Revision: 15545
trunk/.gitattributes
trunk/extras/tiger_geocoder/create_geocode.bat
trunk/extras/tiger_geocoder/upgrade_geocoder.bat
Modified: trunk/.gitattributes
--- trunk/.gitattributes 2017-08-08 19:08:52 UTC (rev 15544)
+++ trunk/.gitattributes 2017-08-08 19:40:04 UTC (rev 15545)
@@ -1,5 +1,3 @@
-*.vcproj eol=crlf
-*.bat eol=crlf
*.sh eol=lf
*.ac eol=lf
*.h.in eol=lf
Modified: trunk/extras/tiger_geocoder/create_geocode.bat
--- trunk/extras/tiger_geocoder/create_geocode.bat 2017-08-08 19:08:52 UTC (rev 15544)
+++ trunk/extras/tiger_geocoder/create_geocode.bat 2017-08-08 19:40:04 UTC (rev 15545)
@@ -1,19 +1,19 @@
-set PGPORT=5432
-set PGHOST=localhost
-set PGUSER=postgres
-set PGPASSWORD=yourpasswordhere
-set THEDB=geocoder
-set PGBIN=C:\Program Files\PostgreSQL\9.1\bin
-set PGCONTRIB=C:\Program Files\PostgreSQL\9.1\share\contrib
-REM "%PGBIN%\psql" -d "%THEDB%" -f "%PGCONTRIB%\fuzzystrmatch.sql"
-REM If you are using PostgreSQL 9.1 or above, use the extension syntax instead as shown below
-"%PGBIN%\psql" -d "%THEDB%" -c "CREATE EXTENSION fuzzystrmatch;"
-"%PGBIN%\psql" -d "%THEDB%" -c "CREATE SCHEMA tiger;"
-REM unremark this next line and edit if you want the search paths set as part of the install
-REM "%PGBIN%\psql" -d "%THEDB%" -c "ALTER DATABASE %THEDB% SET search_path=public, tiger;"
-"%PGBIN%\psql" -d "%THEDB%" -f "create_geocode.sql"
-REM "%PGBIN%\psql" -d "%THEDB%" -f "tables\lookup_tables_2011.sql"
-"%PGBIN%\psql" -d "%THEDB%" -c "CREATE SCHEMA tiger_data;"
-"%PGBIN%\psql" -d "%THEDB%" -f "tiger_loader_2016.sql;"
-pause
+set PGPORT=5432
+set PGHOST=localhost
+set PGUSER=postgres
+set PGPASSWORD=yourpasswordhere
+set THEDB=geocoder
+set PGBIN=C:\Program Files\PostgreSQL\9.1\bin
+set PGCONTRIB=C:\Program Files\PostgreSQL\9.1\share\contrib
+REM "%PGBIN%\psql" -d "%THEDB%" -f "%PGCONTRIB%\fuzzystrmatch.sql"
+REM If you are using PostgreSQL 9.1 or above, use the extension syntax instead as shown below
+"%PGBIN%\psql" -d "%THEDB%" -c "CREATE EXTENSION fuzzystrmatch;"
+"%PGBIN%\psql" -d "%THEDB%" -c "CREATE SCHEMA tiger;"
+REM unremark this next line and edit if you want the search paths set as part of the install
+REM "%PGBIN%\psql" -d "%THEDB%" -c "ALTER DATABASE %THEDB% SET search_path=public, tiger;"
+"%PGBIN%\psql" -d "%THEDB%" -f "create_geocode.sql"
+REM "%PGBIN%\psql" -d "%THEDB%" -f "tables\lookup_tables_2011.sql"
+"%PGBIN%\psql" -d "%THEDB%" -c "CREATE SCHEMA tiger_data;"
+"%PGBIN%\psql" -d "%THEDB%" -f "tiger_loader_2016.sql;"
+pause
Property changes on: trunk/extras/tiger_geocoder/create_geocode.bat
___________________________________________________________________
Deleted: svn:eol-style
- CRLF
Property changes on: trunk/extras/tiger_geocoder/upgrade_geocoder.bat
- CRLF
