[postgis-tickets] [PostGIS] #3803: travis needs to have script revised to work with trusty
PostGIS trac at osgeo.org
Thu Aug 10 02:55:57 PDT 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS 2.3.4
 Component:  buildbots  |    Version:  2.3.x
Resolution:  fixed      |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"15548" 15548]:
 #!CommitTicketReference repository="" revision="15548"
 change back to using the default travis ci - trusty from precise
 Put in place permissions to fix make check error
 Closes #3803 for PostGIS 2.4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3803#comment:3>
