[postgis-tickets] [PostGIS] #3805: No way to create geography that croses -180..180 (date-line)
trac at osgeo.org
Fri Aug 11 12:18:16 PDT 2017
Reporter: OlegSerov | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.4
Component: postgis | Version: 2.3.x
Keywords: |
1. Alaska vs alberta:
SELECT ST_GeogFromText('POLYGON((-116.614 61.7534,-109.804
61.7534,-109.804 57.5029,-116.614 57.5029,-116.614 61.7534))') &&
(ST_GeogFromText(' POLYGON((172.347846 71.441059,-173.233993
71.441059,-158.815832 71.441059,-144.397672 71.441059,-129.979511
71.441059,-129.979511 51.175092,-144.397672 51.175092,-158.815832
51.175092,-173.233993 51.175092,172.347846 51.175092,172.347846
71.441059))'));
Returns TRUE, should return FALSE;
2. 2 parts of Alaska vs alberta
SELECT
ST_GeogFromText('POLYGON((-116.614 61.7534,-109.804 61.7534,-109.804
ST_GeogFromText('MULTIPOLYGON(((-179.999990 71.441059,-167.494870
71.441059,-154.989750 71.441059,-142.484631 71.441059,-129.979511
71.441059,-129.979511 51.175092,-142.484631 51.175092,-154.989750
51.175092,-167.494870 51.175092,-179.999990 51.175092,-179.999990
71.441059)),((172.347846 71.441059,179.999990 71.441059,179.999990
51.175092,172.347846 51.175092,172.347846 71.441059)))');
Returns TRUE, should return false
Version: PostgreSQL 9.3.17 on x86_64-unknown-linux-gnu, compiled by gcc
(Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4, 64-bit POSTGIS="2.3.2 r15302"
GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL
1.10.1, released 2013/08/26" LIBXML="2.9.1" LIBJSON="0.11.99" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3805>
