[postgis-tickets] [PostGIS] #3805: No way to create geography that croses -180..180 (date-line)
trac at osgeo.org
Mon Aug 14 06:10:13 PDT 2017
Reporter: OlegSerov | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.3.4
Component: postgis | Version: 2.3.x
Resolution: invalid | Keywords:
Comment (by OlegSerov):
Let's assume that you are right in the fact that && should somehow work
differently from "ST_Intersects".
But there is still an issue with ST_Intersection:
SELECT ST_Intersection(ST_GeogFromText('POLYGON((-116.614 61.7534,-109.804
61.7534,-109.804 57.5029,-116.614 57.5029,-116.614 61.7534))'),
(ST_GeogFromText(' POLYGON((172.347846 71.441059,-173.233993
71.441059,-158.815832 71.441059,-144.397672 71.441059,-129.979511
71.441059,-129.979511 51.175092,-144.397672 51.175092,-158.815832
51.175092,-173.233993 51.175092,172.347846 51.175092,172.347846
71.441059))')));
ERROR: Error performing intersection: TopologyException: Input geom 1 is
invalid: Self-intersection at or near point -19284319.888845518
6619014.660591769 at -19284319.888845518 6619014.660591769
CONTEXT: SQL function "st_intersection" statement 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3805#comment:2>
