[postgis-tickets] r15555 - Clarify docs wrt purpose of ST_RemoveRepeatedPoints
Daniel Baston
dbaston at gmail.com
Sat Aug 19 09:20:30 PDT 2017
Author: dbaston
Date: 2017-08-19 09:20:30 -0700 (Sat, 19 Aug 2017)
New Revision: 15555
trunk/doc/reference_processing.xml
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2017-08-18 04:02:00 UTC (rev 15554)
+++ trunk/doc/reference_processing.xml 2017-08-19 16:20:30 UTC (rev 15555)
@@ -2560,7 +2560,7 @@
<refnamediv>
<refname>ST_RemoveRepeatedPoints</refname>
<refpurpose>Returns a version of the given geometry with
- duplicated points removed.</refpurpose>
+ consecutive duplicated points removed.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -2575,7 +2575,7 @@
<refsection>
<title>Description</title>
- <para>Returns a version of the given geometry with
+ <para>Returns a version of the given geometry with consecutive
duplicated points removed. Will actually do something only with
(multi)lines, (multi)polygons and multipoints but you can safely call it with
any kind of geometry. Since simplification occurs on a
