[postgis-tickets] r15556 - Remove note about consecutive points. Not the case when called w/MultiPoints.
Daniel Baston dbaston at gmail.com
Sat Aug 19 09:39:12 PDT 2017
Author: dbaston
Date: 2017-08-19 09:39:12 -0700 (Sat, 19 Aug 2017)
New Revision: 15556
   trunk/doc/reference_processing.xml
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml	2017-08-19 16:20:30 UTC (rev 15555)
+++ trunk/doc/reference_processing.xml	2017-08-19 16:39:12 UTC (rev 15556)
@@ -2560,7 +2560,7 @@
 	  <refnamediv>
 		<refname>ST_RemoveRepeatedPoints</refname>
 		<refpurpose>Returns a version of the given geometry with
-				consecutive duplicated points removed.</refpurpose>
+				duplicated points removed.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
@@ -2575,7 +2575,7 @@
 	  <refsection>
 		<title>Description</title>
-		<para>Returns a version of the given geometry with consecutive
+		<para>Returns a version of the given geometry with
 				duplicated points removed. Will actually do something only with
 				(multi)lines, (multi)polygons and multipoints but you can safely call it with
 				any kind of geometry. Since simplification occurs on a
