[postgis-tickets] r15564 - Drop check-installed-upgrades Makefile rule
Sandro Santilli
strk at kbt.io
Mon Aug 21 10:15:14 PDT 2017
Author: strk
Date: 2017-08-21 10:15:14 -0700 (Mon, 21 Aug 2017)
New Revision: 15564
trunk/extensions/upgradeable_versions.mk
You can use utils/check_all_upgrades.sh for this
Modified: trunk/extensions/upgradeable_versions.mk
--- trunk/extensions/upgradeable_versions.mk 2017-08-21 03:48:26 UTC (rev 15563)
+++ trunk/extensions/upgradeable_versions.mk 2017-08-21 17:15:14 UTC (rev 15564)
@@ -28,33 +28,3 @@
2.3.2 \
2.3.3 \
2.4.0alpha
-# This is to avoid forcing "check-installed-upgrades" as a default
-# rule, see https://trac.osgeo.org/postgis/ticket/3420
-all:
-check-installed-upgrades:
- MODULE=$(EXTENSION); \
- TOVER=$(EXTVERSION); \
- EXDIR=`$(PG_CONFIG) --sharedir`/extension; \
- echo MODULE=$${MODULE}; \
- echo TOVER=$${TOVER}; \
- echo EXDIR=$${EXDIR}; \
- ls $${EXDIR}/$${MODULE}--*--$${TOVER}.sql \
- | grep -v unpackaged \
- | while read fname; do \
- p=`echo "$${fname}" | sed "s/.*$${MODULE}--//;s/\.sql$$//"`; \
- FROM=`echo $${p} | sed 's/--.*//'`; \
- FF="$${EXDIR}/$${MODULE}--$${FROM}.sql"; \
- if test -f "$${FF}"; then \
- echo "Testing upgrade path $$p"; \
- $(MAKE) -C ../.. installcheck \
- RUNTESTFLAGS="-v --extension --upgrade-path $$p" \
- echo "Upgrade path $$p failed FF=$${FF}"; \
- exit 1; }; \
- else \
- echo "No install available for upgradeable ext version $${FROM}"; \
- fi; \
- done; \
