[postgis-tickets] [PostGIS] #2411: ST_Reverse returns curves unmodified
PostGIS trac at osgeo.org
Tue Aug 22 05:36:34 PDT 2017
  Reporter:  strk     |      Owner:  strk
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  1.5.X
Resolution:           |   Keywords:
Changes (by strk):
 * owner:  pramsey => strk
 * status:  new => assigned
Comment:
 I've patch ready, with tests.
 Regina do you think it should go in manual that behavior changed/was
 enhanced in 2.4.0 ?
 Or should I rather backport to all supported branches when it makes sense
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2411#comment:6>
