[postgis-tickets] r15568 - Style only change: remove spurious blanks
Sandro Santilli
strk at kbt.io
Tue Aug 22 16:09:16 PDT 2017
Author: strk
Date: 2017-08-22 16:09:16 -0700 (Tue, 22 Aug 2017)
New Revision: 15568
trunk/utils/postgis_proc_upgrade.pl
Modified: trunk/utils/postgis_proc_upgrade.pl
--- trunk/utils/postgis_proc_upgrade.pl 2017-08-22 14:43:42 UTC (rev 15567)
+++ trunk/utils/postgis_proc_upgrade.pl 2017-08-22 23:09:16 UTC (rev 15568)
@@ -18,7 +18,7 @@
# in postgis.sql
# In addition, the transaction contains
-# a check for Major postgis_lib_version()
+# a check for Major postgis_lib_version()
# to match the one contained in lwpostgis.sql
# This never happens by just running make install
@@ -41,7 +41,7 @@
# TODO: move configuration outside of code
my $objs = {
- "102" => {
+ "102" => {
"aggregates" => {
"st_extent(geometry)" => 1,
"st_memcollect(geometry)" => 1,
@@ -53,18 +53,18 @@
"st_makeline(geometry)" => 1
- "105" => {
+ "105" => {
"views" => {
"geography_columns" => 1
- "200" => {
+ "200" => {
"aggregates" => {
"st_3dextent(geometry)" => 1,
"topology.topoelementarray_agg(topology.topoelement)" => 1
- "201" => {
+ "201" => {
"aggregates" => {
"st_samealignment(raster)" => 1,
"st_union(raster,unionarg[])" => 1,
@@ -74,7 +74,7 @@
"st_union(raster,text)" => 1
- "202" => {
+ "202" => {
"aggregates" => {
"st_summarystatsagg(raster,integer,boolean,double precision)" => 1,
"st_summarystatsagg(raster,boolean,double precision)" => 1,
@@ -101,6 +101,7 @@
sub parse_last_updated
my $comment = shift;
+ print STDERR "COMMENT: $comment\n";
if ( $comment =~ m/.*(?:Availability|Changed|Updated):\s([^\.])\.([^.]*)/s ) {
return $1*100 + $2;
@@ -139,7 +140,7 @@
if ( ! -f $sql_file );
-# Search the SQL file for the target version number (the
+# Search the SQL file for the target version number (the
# version we are upgrading *to*.
open( INPUT, $sql_file ) || die "Couldn't open file: $sql_file\n";
@@ -162,7 +163,7 @@
$soname = $1;
-close(INPUT);
+close(INPUT);
die "Unable to locate target new version number in $sql_file\n"
if( ! $version_to );
@@ -170,7 +171,7 @@
if ( $version_to =~ /(\d+)\.(\d+)\..*/ )
$version_to = $1 . "." . $2;
- $version_to_num = 100 * $1 + $2;
+ $version_to_num = 100 * $1 + $2;
else
@@ -201,7 +202,7 @@
-# Go through the SQL file and strip out objects that cannot be
+# Go through the SQL file and strip out objects that cannot be
# applied to an existing, loaded database: types and operators
# and operator classes that have already been defined.
@@ -283,7 +284,7 @@
my $type1 = $1;
my $type2 = $2;
my $def = $_;
- unless (/;$/) {
+ unless (/;$/) {
while(<INPUT>) {
$def .= $_;
last if /;$/;
@@ -335,7 +336,7 @@
\$postgis_proc_upgrade\$;
EOF
# This code handles operators by creating them if we are doing a major upgrade
if ( /^create operator\s+(\S+)\s*\(/i )
@@ -378,7 +379,7 @@
last if /\;\s*$/;
# Always output grant permissions (see ticket #3680)
if ( /^grant select\s+(\S+)\s*/i )
@@ -390,7 +391,7 @@
- # Always output create ore replace rule
+ # Always output create ore replace rule
if ( /^create or replace rule\s+(\S+)\s*/i )
print;
@@ -551,7 +552,7 @@
-- Next releases will still be ok as
-- postgis_lib_version() and MODULE_scripts_installed()
-- would both return actual PostGIS release number.
BEGIN
SELECT into old_scripts MODULE_lib_version();
EXCEPTION WHEN OTHERS THEN
@@ -591,4 +592,4 @@
as version_from_isdev
FROM versions
