[postgis-tickets] [PostGIS] #3813: Dronie and gitlab running GEOS 3.4.2 need to be upgraded to 3.5.0 (was: Dronie is running GEOS 3.4.2 needs to be upgraded to 3.5.0)
trac at osgeo.org
Tue Aug 22 18:39:28 PDT 2017
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.0
Component: buildbots | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> After I made GEOS 3.5.0 minimum, dronie is failing.
New description:
After I made GEOS 3.5.0 minimum, both dronie and gitlab are failing.
https://gitlab.com/postgis/postgis/-/jobs/30018714
both are running GEOS 3.4.2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3813#comment:2>
