[postgis-tickets] r15577 - Revert changes done for gitlab upgrade
Regina Obe
lr at pcorp.us
Wed Aug 23 10:17:30 PDT 2017
Author: robe
Date: 2017-08-23 10:17:30 -0700 (Wed, 23 Aug 2017)
New Revision: 15577
trunk/.gitlab-ci.yml
trunk/NEWS
trunk/configure.ac
trunk/doc/installation.xml
References #3813
Make GEOS 3.4 the new minimum
Closes #3810
Modified: trunk/.gitlab-ci.yml
--- trunk/.gitlab-ci.yml 2017-08-23 16:54:16 UTC (rev 15576)
+++ trunk/.gitlab-ci.yml 2017-08-23 17:17:30 UTC (rev 15577)
@@ -1,10 +1,7 @@
test:
script:
- - apt-get update && apt-get install -y python-software-properties software-properties-common
- - add-apt-repository --yes ppa:ubuntugis/ppa
- - add-apt-repository --yes ppa:ubuntugis/ubuntugis-unstable
- apt-get update -qq && apt-get install -y
- postgresql-9.5 postgresql-server-dev-9.5
+ postgresql-9.4 postgresql-server-dev-9.4
build-essential autoconf libtool libcunit1-dev
xsltproc docbook-xsl docbook-mathml dblatex
libproj-dev libgdal-dev libgeos-dev libjson0-dev
Modified: trunk/NEWS
--- trunk/NEWS 2017-08-23 16:54:16 UTC (rev 15576)
+++ trunk/NEWS 2017-08-23 17:17:30 UTC (rev 15577)
@@ -30,7 +30,7 @@
(Wouter Geraedts)
* Breaking Changes *
- - #3810, GEOS 3.5.0 or above minimum required to compile
+ - #3810, GEOS 3.4.0 or above minimum required to compile
PostGIS 2.4.0alpha
Modified: trunk/configure.ac
--- trunk/configure.ac 2017-08-23 16:54:16 UTC (rev 15576)
+++ trunk/configure.ac 2017-08-23 17:17:30 UTC (rev 15577)
@@ -669,10 +669,10 @@
GEOS_NUMERIC_MINOR_VERSION=`printf "%02d" $GEOS_MINOR_VERSION`
GEOS_NUMERIC_VERSION="$GEOS_MAJOR_VERSION$GEOS_NUMERIC_MINOR_VERSION$GEOS_NUMERIC_PATCH_VERSION"
-dnl Ensure that we are using GEOS >= 3.5.0
+dnl Ensure that we are using GEOS >= 3.4.0
AC_MSG_RESULT([checking GEOS version... $GEOS_FULL_VERSION])
-if test ! "$GEOS_NUMERIC_VERSION" -ge 30500; then
- AC_MSG_ERROR([PostGIS requires GEOS >= 3.5.0])
+if test ! "$GEOS_NUMERIC_VERSION" -ge 30400; then
+ AC_MSG_ERROR([PostGIS requires GEOS >= 3.4.0])
fi
dnl Extract the linker and include flags
Modified: trunk/doc/installation.xml
--- trunk/doc/installation.xml 2017-08-23 16:54:16 UTC (rev 15576)
+++ trunk/doc/installation.xml 2017-08-23 17:17:30 UTC (rev 15577)
@@ -139,8 +139,8 @@
<listitem>
<para>
- GEOS geometry library, version 3.5 or greater, but GEOS 3.7+ is recommended to take full advantage of all the new functions and features. Without GEOS 3.5,
- you will be missing some major enhancements such as <xref linkend="ST_ClipByBox2D" /> and <xref linkend="ST_Subdivide" />. GEOS is available for download from
+ GEOS geometry library, version 3.4 or greater, but GEOS 3.7+ is recommended to take full advantage of all the new functions and features. You should have at least GEOS 3.5,
+ without which you will be missing some major enhancements such as <xref linkend="ST_ClipByBox2D" /> and <xref linkend="ST_Subdivide" />. GEOS is available for download from
<ulink url="http://trac.osgeo.org/geos/">
</ulink> and 3.5+ is backward-compatible with older versions so fairly safe to upgrade.
