[postgis-tickets] r15578 - Revise comment format of some aggregates so that postgis upgrade script generator picks them up
Regina Obe
lr at pcorp.us
Wed Aug 23 16:56:33 PDT 2017
Author: robe
Date: 2017-08-23 16:56:33 -0700 (Wed, 23 Aug 2017)
New Revision: 15578
trunk/postgis/postgis.sql.in
Closes #3812
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2017-08-23 17:17:30 UTC (rev 15577)
+++ trunk/postgis/postgis.sql.in 2017-08-23 23:56:33 UTC (rev 15578)
@@ -3849,7 +3849,7 @@
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
-- Availability: 1.2.2
--- Changed 2.4.0: marked parallel safe
+-- Changed: 2.4.0 marked parallel safe
CREATE AGGREGATE ST_Union (geometry) (
sfunc = pgis_geometry_accum_transfn,
stype = pgis_abs,
@@ -3860,7 +3860,7 @@
+-- Changed: 2.4.0: marked parallel safe
CREATE AGGREGATE ST_Collect (geometry) (
SFUNC = pgis_geometry_accum_transfn,
STYPE = pgis_abs,
@@ -3871,7 +3871,7 @@
-- Availability: 2.2
CREATE AGGREGATE ST_ClusterIntersecting (geometry) (
STYPE = pgis_abs,
@@ -3882,7 +3882,7 @@
CREATE AGGREGATE ST_ClusterWithin (geometry, float8) (
STYPE = pgis_abs,
@@ -3893,7 +3893,7 @@
CREATE AGGREGATE ST_Polygonize (geometry) (
STYPE = pgis_abs,
@@ -3904,7 +3904,7 @@
CREATE AGGREGATE ST_MakeLine (geometry) (
STYPE = pgis_abs,
