[postgis-tickets] [PostGIS] #3698: CENSUS Download path for TABBLOCK
trac at osgeo.org
Wed Aug 23 19:41:25 PDT 2017
Reporter: EvanCarroll | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.3.4
Component: tiger geocoder | Version: 2.3.x
Resolution: | Keywords:
Comment (by robe):
Jeffrey,
Thanks for the experiment. I've incorporated your changes into code, but
to fix the tabblock10/tabblock10 issue I had to modify the loader scripts
a bit.
I also realized the census script was a bit broken so fixing that as well.
And then also discovered census is using SSLV3 as noted in #3816.
I'm doing some testing of states before I commit my changes.
What I will do is keep tabblock, bg off since there is nothing in the code
that uses those tables. tract I'm tempted to turn off as well by default
except I have get_tract function that uses it.
I'll update the docs with an update statement for people that want those
tables loaded and also show how to use the loader_generate_census_script
which I have set to download bg, tract, tabblock regardless of if they are
turned off in the lookup_tables.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3698#comment:15>
