[postgis-tickets] [PostGIS] #3765: geometry regress failure
PostGIS trac at osgeo.org
Sat Aug 26 23:51:31 PDT 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  medium     |  Milestone:  PostGIS 2.4.0
 Component:  buildbots  |    Version:  trunk
Resolution:  fixed      |   Keywords:
Changes (by robe):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"15596" 15596]:
 #!CommitTicketReference repository="" revision="15596"
 ST_GeneratePoints check to use ST_Intersects instead of ST_Contains
 Minimize failures when point falls on the boundary.
 Closes #3765 for PostGIS 2.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3765#comment:6>
