[postgis-tickets] [PostGIS] #3821: Don't drop st_union when updating postgis extension to 2.4
trac at osgeo.org
Mon Aug 28 08:08:04 PDT 2017
Reporter: nextstopsun | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by robe):
Unfortunately short of mucking with the system catalogs I don't think so.
PostgreSQL doesn't have a create or replace agg like it does for functions
and in 2.4 we marked most aggs parallel safe so they need drop/recreate
for the changes to take effect.
and alter aggregate doesn't give us much power except to rename aggs.
https://www.postgresql.org/docs/9.6/static/sql-alteraggregate.html
What you could do, if you are on PostgreSQL 9.5 or lower these extra
clauses aren't in there so in theory you shouldn't need to drop, so you
could just remark out the DROP AGG .. CREATE AGG in the extension scripts.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3821#comment:1>
