[postgis-tickets] [PostGIS] #3821: Don't drop st_union when updating postgis extension to 2.4
PostGIS trac at osgeo.org
Mon Aug 28 12:24:00 PDT 2017
  Reporter:  nextstopsun  |      Owner:  robe
      Type:  defect       |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 2.5.0
 Component:  postgis      |    Version:  2.3.x
Resolution:               |   Keywords:
Comment (by robe):
 Sadly I'm afraid since we don't keep track of changes within dev, going
 from PostGIS 2.4.0dev to PostGIS 2.4.0devnext for example will always try
 to drop and recreate the aggs.  Fussing with sys catalogs is beginning to
 feel more appealing to me now.
 What you could do for now if you really don't want to drop and recreate
 the aggs (or you just need to do it for ST_Union) , is  in the extension
 scripts -- e.g. postgis--2.4.0devnext--2.4.0dev.sql
 where it has
 OR (
       204 = version_from_num AND version_from_isdev
  Wipe that out and it won't force drop and recreate aggs.  Again you can
 maybe just do it for ST_Union since I think ST_ASMVT has some aggs and
 those changes you might want to do.
 I have to lookup the sys catalogs but I think there is a way to directly
 update the sys catalogs to set the parallel safe bit on by directly
 updating the catalogs.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3821#comment:11>
