[postgis-tickets] [PostGIS] #3822: Have postgis_full_version() also denote which version of PostgreSQL the scripts were built against
PostGIS trac at osgeo.org
Mon Aug 28 13:06:27 PDT 2017
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.5.0
Component:  postgis  |    Version:  2.3.x
 Keywords:           |
 Right now our postgis_full_version() will only warn if the scripts are
 older PostGIS micro from PostGIS binary.
 This makes it possible for example for someone to do a
 soft upgrade from 2.2 to 2.3 on PostgreSQL 9.3
 and then a pg_upgrade to PostgreSQL 9.5 and not know that they are missing
 the new BRIN operators or KNN true dist operators
 SELECT postgis_full_version();
 should warn and tell them to run something like
 ALTER EXTENSION postgis UPDATE postgis-2.3.4next;
 ALTER EXTENSION postgis UPDATE postgis-2.3.4;
 to fix the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3822>
