[postgis-tickets] [PostGIS] #3821: Don't drop st_union when updating postgis extension to 2.4
PostGIS trac at osgeo.org
Mon Aug 28 21:11:04 PDT 2017
  Reporter:  nextstopsun  |      Owner:  robe
      Type:  defect       |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 2.5.0
 Component:  postgis      |    Version:  2.3.x
Resolution:               |   Keywords:
Comment (by robe):
 That works for me strk:
 When I do this from psql
 \df+ ST_Union
 it toggles to safe and setting it to 'u' switches it to unsafe.
 Now is it worthwhile to make an exception for ST_Union that it's used
 enough in views that we should just do the unholy and update the system
 catalog just for this agg function for PostgreSQL 9.6+ users upgrading to
 2.4.
 and take out the changed flag on it or should we just advice folks steps
 to take to upgrade if they run into the issue?
 nextstopsun -- what do you think are our instructions okay for you to
 follow
 1) remove the:
 OR (
       204 = version_from_num AND version_from_isdev
 2) Do the update thing that strk mentioned -- this will work too:
 UPDATE pg_proc SET proparallel = 's'
 WHERE oid = 'st_union(geometry)'::regprocedure;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3821#comment:14>
