[postgis-tickets] [PostGIS] #3823: ST_MinimumBoundingCircle creates invalid geometries
trac at osgeo.org
Tue Aug 29 08:54:03 PDT 2017
Reporter: cswingle | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.4
Component: postgis | Version: 2.3.x
Keywords: ST_MinimumBoundingCircle |
Certain combinations of PostGIS 2.3.3 and dependent libraries cause
ST_MinimumBoundingCircle to create invalid geometries.
For example on an Ubuntu Xenial, AMD64 system (with ubuntugis-unstable):
POSTGIS="2.3.3 r15473"
GEOS="3.5.1-CAPI-1.9.1 r4246"
PROJ="Rel. 4.9.2, 08 September 2015"
GDAL="GDAL 1.11.3, released 2015/09/16"
LIBXML="2.9.3"
LIBJSON="0.11.99" RASTER
SELECT ST_IsValid(ST_MinimumBoundingCircle(ST_GeomFromText(
'MULTIPOINT(-150.646548 69.6052122,
-150.641227 69.578776,
-150.659938 69.575257)')));
NOTICE: IllegalArgumentException: Points of LinearRing do not form a
closed linestring
st_isvalid
f
The same SQL is successful on several other identical versions of PostGIS,
but with different libraries. These are two example systems where it
works (Debian stretch and Debian jessie, AMD64):
PROJ="Rel. 4.9.3, 15 August 2016"
GDAL="GDAL 2.1.2, released 2016/10/24"
LIBXML="2.9.4"
LIBJSON="0.12.1" RASTER
GEOS="3.4.2-CAPI-1.8.2 r3921"
PROJ="Rel. 4.8.0, 6 March 2012"
GDAL="GDAL 1.10.1, released 2013/08/26"
LIBXML="2.9.1"
Since it's the same version of PostGIS each time, it seems likely that
it's another library causing the issue but I don't know enough about these
interactions to identify a culprit or a solution for my Xenial system.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3823>
