[postgis-tickets] [PostGIS] #3819: ST_AsMVTGeom changes line direction
trac at osgeo.org
Tue Aug 29 09:48:42 PDT 2017
Reporter: nextstopsun | Owner: Björn Harrtell
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by Björn Harrtell):
* status: closed => reopened
* resolution: fixed =>
Comment:
Still appears to be an issue. I kept ST_Normalize as the last step which I
didn't think would change orientation but it probably does. Will move that
logic to tests where it belongs (was only added to get consistent output
for the test cases).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3819#comment:9>
