[postgis-tickets] [PostGIS] #3823: ST_MinimumBoundingCircle creates invalid geometries
trac at osgeo.org
Wed Aug 30 08:59:56 PDT 2017
Reporter: cswingle | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.4
Component: postgis | Version: 2.3.x
Resolution: | Keywords: ST_MinimumBoundingCircle
Comment (by dbaston):
Very helpful, thanks. The computed radius of NaN is pretty suspect!
This behavior isn't related to the dependent libraries, but it could
conceivably vary from machine to machine based on the compiler used, etc.
I'm guessing this has something to do with a the small number of
coordinates and presence of a duplicate coordinate.
As a workaround, I'm almost certain you'll see correct values if you wrap
your inputs in {{{ST_UnaryUnion}}}.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3823#comment:4>
