[postgis-tickets] [PostGIS] #3825: Running an ST_Intersect with PostGIS Geography with large extents returns incorrect results.
trac at osgeo.org
Thu Aug 31 15:49:38 PDT 2017
incorrect results.
Reporter: just7460 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.4
Component: postgis | Version: 2.3.x
Keywords: Geography, postgis |
SYNOPSIS:
When trying to find which features from a table intersect with a large
provided extent, only a portion of the expected features are returned. The
provided extent is significantly larger than the extent holding the
features.
More specifically, the table contains 4 features which are all located in
North America. The SQL statements all attempt to find the features which
intersect with a shape that extends to roughly the entire globe.
Attempting to find the features that intersect with a polygon created by
the 4 most extreme points will return 0 results. Because I assumed that
PostGIS Geography uses Great Circles, I also included some SQL which
attempts to find the intersecting features with a densified polygon. This
seems to find some of the features, but are still missing some.
POSTGRESQL SPECIFIC INFORMATION:
Version:
"PostgreSQL 9.6.3, compiled by Visual C++ build 1800, 64-bit"
Special Installation requirements:
N/A
Special startup parameters:
N/A
OPERATING SYSTEM INFORMATION:
OS: Windows 8.1 Enterprise
Processor: Intel® Xeon® CPU E5-1620 v3 @ 3.50GHz
System type: 64-bit Operating System, x64-based processor
STEPS TO REPRODUCE:
Run the following SQL, or run the attached .sql file via psql.
DROP TABLE IF EXISTS geog_intersect;
CREATE TABLE geog_intersect (
oid serial NOT NULL,
code VARCHAR(3),
geog Geography (Geometry, 4326)
INSERT INTO geog_intersect (geog)
VALUES (ST_GeogFromText('SRID=4326; Point (-110.45 57.54)'));
VALUES (ST_GeogFromText('SRID=4326; Point ( -98.57 54.63)'));
VALUES (ST_GeogFromText('SRID=4326; Point ( -89.84 52.69)'));
VALUES (ST_GeogFromText('SRID=4326; Point (-101.24 62.14)'));
create index spa_idx on geog_intersect USING GIST (geog);
select oid, ST_AsText(geog) AS geog from geog_intersect
where (geog && ST_GeogFromText('SRID=4326; POLYGON ((
-179.99 -89.99, 179.99 -89.99, 179.99 89.99, -179.99 89.99, -179.99
-89.99))') = 't');
-179.99 -89.99, -159.99 -89.99, -139.99 -89.99, -119.99 -89.99, -99.99
-89.99,
-80.00 -89.99, -60.00 -89.99, -40.00 -89.99, -20.00 -89.99, -0.00 -89.99,
20.00 -89.99,
40.00 -89.99, 60.00 -89.99, 80.00 -89.99, 99.99 -89.99, 119.99 -89.99,
139.99 -89.99,
179.99 -89.99,
179.99 -45.00,
179.99 0.00,
179.99 45.00,
179.99 89.99, 159.99 89.99, 139.99 89.99, 119.99 89.99, 99.99 89.99,
80.00 89.99,
60.00 89.99, 40.00 89.99, 20.00 89.99, 0.00 89.99, -20.00 89.99, -40.00
89.99,
-60.00 89.99, -80.00 89.99, -99.99 89.99, -119.99 89.99, -139.99 89.99,
-179.99 89.99,
-179.99 45.00,
-179.99 0.00,
-179.99 -45.00,
-179.99 -89.99))') = 't');
select oid, ST_AsText(geog) as geog from geog_intersect
where ST_Intersects(geog, ST_GeogFromText('SRID=4326; POLYGON ((
-89.99))')) = 't';
-89.99,
20.00 -89.99,
139.99 -89.99,
179.99 -89.99,
80.00 89.99,
89.99,
-179.99 89.99,
-179.99 -89.99))')) = 't';
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3825>
