[postgis-tickets] [PostGIS] #3940: Regression failures on Bessies - FReeBSD 11 bots
PostGIS trac at osgeo.org
Mon Dec 11 20:59:07 PST 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.5.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Description changed by robe:
Old description:
> Getting some weird failures on FreeBSD bots.  Unfortunately not sure how
> long it's been happening since I had an issue with the regress database
> not being dropped.
> I'm also going to do a clean checkout to make sure it's not a something
> to do with dirty install.
> The error from 64-bit looks like this a lot of proj type looking errors
> 04:50:54  out_geometry .. failed (diff expected obtained:
> /home/jenkins/tmp/pgis_reg_trunk/test_55_diff)
> 04:50:54
> 04:50:54 --- out_geometry_expected      2017-11-28 18:23:08.079753000
> +0000
> 04:50:54 +++ /home/jenkins/tmp/pgis_reg_trunk/test_55_out
> 2017-12-11 23:49:31.008324000 +0000
> 04:50:54 @@ -27,8 +27,8 @@
> 04:50:54
> gml_out_curve_03|<gml:Polygon><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList
> srsDimension="2">-2 0 -1 -1 0 0 1 -1 2 0 0 2 -2
> 0</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:Ring></gml:exterior><gml:interior><gml:LinearRing><gml:posList
> srsDimension="2">-1 0 0 0.5 1 0 0 1 -1
> 0</gml:posList></gml:LinearRing></gml:interior></gml:Polygon>
> 04:50:54
> gml_out_curve_04|<gml:MultiCurve><gml:curveMember><gml:Curve><gml:segments><gml:LineStringSegment><gml:posList
> srsDimension="2">5 5 3 5 3 3 0
> 3</gml:posList></gml:LineStringSegment></gml:segments></gml:Curve></gml:curveMember><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList
> srsDimension="2">0 0 2 1 2
> 2</gml:posList></gml:ArcString></gml:segments></gml:Curve></gml:curveMember></gml:MultiCurve>
> 04:50:54
> gml_out_curve_05|<gml:MultiSurface><gml:Polygon><gml:exterior><gml:Ring><gml:curveMember><gml:Curve><gml:segments><gml:ArcString><gml:posList
> 0</gml:posList></gml:LinearRing></gml:interior></gml:Polygon><gml:Polygon><gml:exterior><gml:LinearRing><gml:posList
> srsDimension="2">7 8 10 10 6 14 4 11 7
> 8</gml:posList></gml:LinearRing></gml:exterior></gml:Polygon></gml:MultiSurface>
> 04:50:54 -ERROR:  GetProj4StringSPI: Cannot find SRID (10) in
> spatial_ref_sys
> 04:50:54 -ERROR:  Input geometry has unknown (0) SRID
> 04:50:54 +kml_srid_01|<Point><coordinates>0,1</coordinates></Point>
> 04:50:54 +kml_srid_02|<Point><coordinates>0,1</coordinates></Point>
> 04:51:00  regress_proj .. failed (diff expected obtained:
> /home/jenkins/tmp/pgis_reg_trunk/test_70_diff)
> 04:51:00
> 04:51:00 --- regress_proj_expected      2017-11-28 18:23:08.196550000
> +0000
> 04:51:00 +++ /home/jenkins/tmp/pgis_reg_trunk/test_70_out
> 2017-12-11 23:49:36.271043000 +0000
> 04:51:00 @@ -1,11 +1,11 @@
> 04:51:00  0|EMPTY
> 04:51:00 -1|SRID=100001;POINT(574600 5316780)
> 04:51:00 -2|SRID=100001;POINT(574600 5316780 171)
> 04:51:00 -3|SRID=100001;POINT(574600 5316780 171 -500)
> 04:51:00 -4|SRID=100001;LINESTRING(574600 5316780,573140 5427940)
> 04:51:00 -5|SRID=100001;LINESTRING(574600 5316780 0 0,573140 5427940 0 0)
> 04:51:00 +1|SRID=100002;POINT(20 50)
> 04:51:00 +2|SRID=100002;POINT(20 50 171)
> 04:51:00 +3|SRID=100002;POINT(20 50 171 -500)
> 04:51:00 +4|SRID=100002;LINESTRING EMPTY
> 04:51:00 +5|SRID=100002;LINESTRING EMPTY
> 04:51:00  6|16.00000000|48.00000000
> 04:51:00 -ERROR:  Input geometry has unknown (0) SRID
> 04:51:00 +010100000000000000000000000000000000000000
> 04:51:00  8|SRID=100002;POINT(0 0)
> 04:51:00  9|POINT(574600 5316780)
> 04:51:00  10|POINT(574600 5316780)
> 04:51:00
> 04:51:04  #408|Too few points in geometry component[
> 04:51:04 @@ -123,7 +133,7 @@
> 04:51:04  #695
> 04:51:04  ERROR:  First argument must be a LINESTRING
> 04:51:04
> #696|010f000080060000000103000080010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000010300008001000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000005000000000000000000000000000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000000001030000800100000005000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000010300008001000000050000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000103000080010000000500000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f
> 04:51:04 -#720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91
> 7326837.72,-1113194.91 11028513.63,556597.45 4838471.4,556597.45
> 7326837.72,556597.45 11028513.63,2226389.82 4838471.4,2226389.82
> 7326837.72,2226389.82 11028513.63,3896182.18 4838471.4,3896182.18
> 7326837.72,3896182.18 11028513.63,5565974.54 4838471.4,5565974.54
> 7326837.72,5565974.54 11028513.63)
> 04:51:04 +#720|MULTIPOINT(-10 40,-10 55,-10 70,5 40,5 55,5 70,20 40,20
> 55,20 70,35 40,35 55,35 70,50 40,50 55,50 70)
> 04:51:04  #723|0101000020e61000006284f068e33826c00000000000004440
> 04:51:04  #723|0107000020e610000000000000
> 04:51:04 @@ -187,7 +197,7 @@
> 04:51:04  #852.2|1|t|t
> 04:51:04  #852.2|2|t|t
> 04:51:04  #1489|MULTIPOINT EMPTY|0|MULTILINESTRING EMPTY|0|MULTIPOLYGON
> EMPTY|0|GEOMETRYCOLLECTION EMPTY|0
> 04:51:04 -ERROR:  AddToPROJ4SRSCache: could not parse proj4 string ''
> 04:51:04 +#1150|POINT(0 0)
> 04:51:15  knn_recheck .. failed (diff expected obtained:
> /home/jenkins/tmp/pgis_reg_trunk/test_97_diff)
> 04:51:29
> 04:51:29 --- knn_recheck_expected       2017-11-28 18:23:08.047960000
> +0000
> 04:51:29 +++ /home/jenkins/tmp/pgis_reg_trunk/test_97_out
> 2017-12-11 23:50:05.996983000 +0000
> 04:51:29 @@ -38,30 +38,16 @@
> 04:51:29  #3|500101|600001|1106.0791|1106.0791
> 04:51:29  #3|500101|600002|1210.3577|1210.3577
> 04:51:29  #3|500101|12905|1239.5484|1239.5484
> 04:51:29 -#1g|500000|0.0000|0.0000
> 04:51:29 -#1g|600003|69974.6935|69974.6935
> 04:51:29 -#1g|2614|70976.1794|70976.1794
> 04:51:29 -#1g|2615|75048.8551|75048.8551
> 04:51:29 -#1g|2795|86965.9298|86965.9298
> 04:51:29 -#2g|31244|4189.9122|4189.9122
> 04:51:29 -#2g|31061|6756.6424|6756.6424
> 04:51:29 -#2g|30878|15161.4706|15161.4706
> 04:51:29 -#2g|30695|21264.3654|21264.3654
> 04:51:29 -#2g|30512|25313.2118|25313.2118
> 04:51:29 -#3g|1000|t
> 04:51:29 -#3g|500000|t
> 04:51:29 +NOTICE:  Coordinate values were coerced into range [-180 -90,
> 180 90] for GEOGRAPHY
> 04:51:29 +ERROR:  BOOM! Could not generate outside point!
> 04:51:29  #1nd-3|290|260.6797|260.6797
> 04:51:29  #1nd-3|287|264.3000|264.3000
> 04:51:29  #1nd-3|579|265.4356|265.4356
> 04:51:29
> and others
New description:
 not being dropped.
 I'm also going to do a clean checkout to make sure it's not a something to
 04:48:26  -------------- Dependencies --------------
 04:48:26   GEOS config:          /usr/local/bin/geos-config
 04:48:26   GEOS version:         3.6.2
 04:48:26   GDAL config:          /usr/local/bin/gdal-config
 04:48:26   GDAL version:         2.2.2
 04:48:26   SFCGAL config:        /usr/local/bin/sfcgal-config
 04:48:26   SFCGAL version:       1.3.1
 04:48:26   PostgreSQL config:    /usr/local/bin/pg_config
 04:48:26   PostgreSQL version:   PostgreSQL 10.1
 04:48:26   PROJ4 version:        49
 04:48:26   Libxml2 config:       /usr/local/bin/xml2-config
 04:48:26   Libxml2 version:      2.9.4
 04:48:26   JSON-C support:       no
 04:48:26   protobuf-c support:   no
 04:48:26   PCRE support:         no
 04:48:26   Perl:                 /usr/local/bin/perl
 04:48:26
 04:48:26  --------------- Extensions ---------------
 04:48:26   PostGIS Raster:       enabled
 04:48:26   PostGIS Topology:     enabled
 04:48:26   SFCGAL support:       enabled
 04:48:26   Address Standardizer support:       disabled
 04:48:26
 04:48:26  -------- Documentation Generation --------
 04:48:26   xsltproc:             /usr/local/bin/xsltproc
 04:48:26   xsl style sheets:
 04:48:26   dblatex:
 04:48:26   convert:              /usr/local/bin/convert
 04:48:26   mathml2.dtd:
 http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
 04:50:54
 +0000
 04:50:54 +++ /home/jenkins/tmp/pgis_reg_trunk/test_55_out       2017-12-11
 04:50:54
 04:50:54
 04:50:54
 spatial_ref_sys
 04:51:00
 +0000
 04:51:00 +++ /home/jenkins/tmp/pgis_reg_trunk/test_70_out       2017-12-11
 04:51:00  0|EMPTY
 04:51:00
 04:51:04  #695
 04:51:04
 04:51:29
 +0000
 04:51:29 +++ /home/jenkins/tmp/pgis_reg_trunk/test_97_out       2017-12-11
 04:51:29
 and others
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3940#comment:1>
