[postgis-tickets] [PostGIS] #3940: Regression failures on Bessies - FreeBSD 11 bots (was: Regression failures on Bessies - FReeBSD 11 bots)
trac at osgeo.org
Mon Dec 11 22:07:34 PST 2017
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.0
Component: buildbots | Version: trunk
Resolution: | Keywords:
Changes (by robe):
* owner: robe => pramsey
Comment:
Confirmed it is r16143 (I retested both r16142 and r16143). r16142 was
fine and things going south at r16143.
Creating database 'postgis_reg'
Preparing db 'postgis_reg' using: CREATE EXTENSION postgis
PostgreSQL 10.1 on amd64-portbld-freebsd11.0, compiled by FreeBSD clang
version 3.8.0 (tags/RELEASE_380/final 262564) (based on LLVM 3.8.0), 64
Postgis 2.5.0dev - r16143 - 2017-12-12 00:50:31
scripts 2.5.0dev r16143
raster scripts 2.5.0dev r16143
GEOS: 3.6.2-CAPI-1.10.2 4d2925d6
PROJ: Rel. 4.9.3, 15 August 2016
SFCGAL: 1.3.1
GDAL: GDAL 2.2.2, released 2017/09/15
Running tests
loader/Point .............. ok
loader/PointM .............. ok
loader/PointZ .............. ok
loader/MultiPoint .............. ok
loader/MultiPointM .............. ok
loader/MultiPointZ .............. ok
loader/Arc .............. ok
loader/ArcM .............. ok
loader/ArcZ .............. ok
loader/Polygon .............. ok
loader/PolygonM .............. ok
loader/PolygonZ .............. ok
loader/TSTPolygon ......... ok
loader/TSIPolygon ......... ok
loader/TSTIPolygon ......... ok
loader/PointWithSchema ..... ok
loader/NoTransPoint ......... ok
loader/NotReallyMultiPoint ......... ok
loader/MultiToSinglePoint ......... ok
loader/ReprojectPts .... failed ( wkt test: running shp2pgsql output:
/root/tmp/pgis_reg_2.5/loader.err)
loader/ReprojectPtsGeog .... failed ( wkt test: running shp2pgsql output:
loader/Latin1 .... ok
loader/Latin1-implicit .... ok
loader/mfile .... ok
dumper/literalsrid ....... ok
dumper/realtable ....... ok
affine .. ok
bestsrid .. ok
binary .. ok
boundary .. ok
cluster .. ok
concave_hull .. ok
ctors .. ok
curvetoline .. ok
dump .. ok
dumppoints .. ok
empty .. ok
estimatedextent .. ok
forcecurve .. ok
geography .. ok
geometric_median .. ok
in_geohash .. ok
in_gml .. ok
in_kml .. ok
in_encodedpolyline .. ok
iscollection .. ok
legacy .. ok
long_xact .. ok
lwgeom_regress .. ok
measures .. ok
minimum_bounding_circle .. ok
normalize .. ok
operators .. ok
orientation .. ok
out_geometry .. failed (diff expected obtained:
/root/tmp/pgis_reg_2.5/test_55_diff)
out_geography .. ok
polygonize .. ok
polyhedralsurface .. ok
postgis_type_name .. ok
regress .. ok
regress_bdpoly .. ok
regress_index .. ok
regress_index_nulls .. ok
regress_management .. ok
regress_selectivity .. ok
regress_lrs .. ok
regress_ogc .. ok
regress_ogc_cover .. ok
regress_ogc_prep .. ok
regress_proj .. failed (diff expected obtained:
/root/tmp/pgis_reg_2.5/test_70_diff)
relate .. ok
remove_repeated_points .. ok
removepoint .. ok
reverse .. ok
setpoint .. ok
simplify .. ok
simplifyvw .. ok
size .. ok
snaptogrid .. ok
split .. ok
sql-mm-serialize .. ok
sql-mm-circularstring .. ok
sql-mm-compoundcurve .. ok
sql-mm-curvepoly .. ok
sql-mm-general .. ok
sql-mm-multicurve .. ok
sql-mm-multisurface .. ok
swapordinates .. ok
summary .. ok
temporal .. ok
tickets .. failed (diff expected obtained:
/root/tmp/pgis_reg_2.5/test_91_diff)
twkb .. ok
typmod .. ok
wkb .. ok
wkt .. ok
wmsservers .. ok
knn_recheck .. failed (diff expected obtained:
/root/tmp/pgis_reg_2.5/test_97_diff)
temporal_knn .. ok
hausdorff .. ok
regress_buffer_params .. ok
offsetcurve .. ok
relatematch .. ok
isvaliddetail .. ok
sharedpaths .. ok
snap .. ok
node .. ok
unaryunion .. ok
clean .. ok
relate_bnr .. ok
delaunaytriangles .. ok
clipbybox2d .. ok
subdivide .. ok
voronoi .. ok
minimum_clearance .. ok
regress_brin_index .. ok
regress_brin_index_3d .. ok
regress_brin_index_geography .. ok
regress_sfcgal .. ok
sfcgal/empty .. ok
sfcgal/geography .. ok
sfcgal/legacy .. ok
sfcgal/measures .. ok
sfcgal/regress_ogc_prep .. ok
sfcgal/regress_ogc .. ok
sfcgal/regress .. ok
sfcgal/tickets .. failed (diff expected obtained:
/root/tmp/pgis_reg_2.5/test_126_diff)
sfcgal/concave_hull .. ok
sfcgal/wmsservers .. ok
sfcgal/approximatemedialaxis .. ok
uninstall .. ok (4663)
Run tests: 130
Failed: 7
gmake[2]: *** [Makefile:303: check] Error 7
gmake[2]: Leaving directory '/usr/home/jenkins/workspace/2.5/regress'
gmake[1]: *** [GNUmakefile:16: check] Error 1
gmake[1]: Leaving directory '/usr/home/jenkins/workspace/2.5'
*** Error code 2
Switching over to pramsey
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3940#comment:4>
