[postgis-tickets] r16148 - Move input_srid == output_srid check after input_srid is initialized
Regina Obe
lr at pcorp.us
Tue Dec 12 14:16:55 PST 2017
Author: robe
Date: 2017-12-12 14:16:55 -0800 (Tue, 12 Dec 2017)
New Revision: 16148
trunk/postgis/lwgeom_transform.c
Closes #3940
Modified: trunk/postgis/lwgeom_transform.c
--- trunk/postgis/lwgeom_transform.c 2017-12-12 18:10:09 UTC (rev 16147)
+++ trunk/postgis/lwgeom_transform.c 2017-12-12 22:16:55 UTC (rev 16148)
@@ -59,12 +59,15 @@
PG_RETURN_NULL();
+ geom = PG_GETARG_GSERIALIZED_P_COPY(0);
+ input_srid = gserialized_get_srid(geom);
+ /* Moved this back down after input_srid set otherwise FreeBSD 11 (bessie goes nuts)
+ Refer to https://trac.osgeo.org/postgis/ticket/3940 */
/* Input SRID and output SRID are equal, noop */
if ( input_srid == output_srid )
PG_RETURN_POINTER(PG_GETARG_DATUM(0));
- geom = PG_GETARG_GSERIALIZED_P_COPY(0);
- input_srid = gserialized_get_srid(geom);
if ( input_srid == SRID_UNKNOWN )
PG_FREE_IF_COPY(geom, 0);
@@ -72,6 +75,8 @@
PG_RETURN_NULL();
if ( GetProjectionsUsingFCInfo(fcinfo, input_srid, output_srid, &input_pj, &output_pj) == LW_FAILURE )
