[postgis-tickets] r16152 - [travis] Run Travis builds with -Werror
Darafei
komzpa at gmail.com
Fri Dec 15 05:25:38 PST 2017
Author: komzpa
Date: 2017-12-15 05:25:38 -0800 (Fri, 15 Dec 2017)
New Revision: 16152
trunk/.travis.yml
Closes #3943
Closes https://github.com/postgis/postgis/pull/163
Modified: trunk/.travis.yml
--- trunk/.travis.yml 2017-12-13 20:51:36 UTC (rev 16151)
+++ trunk/.travis.yml 2017-12-15 13:25:38 UTC (rev 16152)
@@ -1,25 +1,35 @@
env:
global:
- RUNTESTFLAGS=-v
+ - CFLAGS="-O3 -fno-omit-frame-pointer -Werror"
addons:
postgresql: "9.6"
+ apt:
+ packages:
+ - postgresql-server-dev-9.6
+ - libxml2-utils
+ - libcunit1-dev
+ - xsltproc
+ - docbook-xsl
+ - docbook-mathml
+ - dblatex
+ - libgeos-dev
+ - libjson0-dev
+ - libprotobuf-c0-dev
+ - libgdal-dev
+ - eatmydata
before_install:
- - sudo add-apt-repository --yes ppa:ubuntugis/ppa
- - sudo add-apt-repository --yes ppa:ubuntugis/ubuntugis-unstable
- - sudo apt-get update -qq
- - sudo apt-get install -y --no-install-recommends
- postgresql-9.6 postgresql-server-dev-9.6 libxml2-utils
- libcunit1-dev xsltproc docbook-xsl docbook-mathml dblatex
- libgdal-dev libgeos-dev libjson0-dev
- libsfcgal1 libsfcgal-dev libprotobuf-c0-dev libgdal-dev
- - dpkg -l | grep postgresql
+ - sudo eatmydata add-apt-repository --yes ppa:ubuntugis/ppa
+ - sudo eatmydata add-apt-repository --yes ppa:ubuntugis/ubuntugis-unstable
+ - sudo eatmydata apt-get update -qq
+ - sudo eatmydata apt-get install -y --no-install-recommends --no-install-suggests libsfcgal1 libsfcgal-dev
- wget http://download.osgeo.org/proj/proj-4.9.2.tar.gz
- tar zxvf proj-4.9.2.tar.gz
- cd proj-4.9.2
- - ./configure --prefix=/usr
- - make
+ - CFLAGS="-O3" ./configure --prefix=/usr
+ - CFLAGS="-O3" eatmydata make -j
- sudo make install
- cd ..
- rm -rf proj-4.9.2
@@ -37,13 +47,13 @@
script:
- ./configure
- - make
+ - eatmydata make -j
- chmod 755 /home/travis
- - make check
- - make check RUNTESTFLAGS='--dumprestore'
+ - eatmydata make check
+ - eatmydata make check RUNTESTFLAGS='--dumprestore'
- sudo make install
- - make installcheck
- - make installcheck RUNTESTFLAGS='--dumprestore'
+ - eatmydata make installcheck
+ - eatmydata make installcheck RUNTESTFLAGS='--dumprestore'
notifications:
email: false
