[postgis-tickets] r16160 - Force drop of regression database if it exists in debbie too
Sandro Santilli
strk at kbt.io
Mon Dec 18 08:52:50 PST 2017
Author: strk
Date: 2017-12-18 08:52:50 -0800 (Mon, 18 Dec 2017)
New Revision: 16160
trunk/ci/debbie/postgis_regress.sh
Or it keeps blaming me for this failure:
https://debbie.postgis.net/job/GDAL_PostGIS_Regress/5373/console
Modified: trunk/ci/debbie/postgis_regress.sh
--- trunk/ci/debbie/postgis_regress.sh 2017-12-18 14:54:00 UTC (rev 16159)
+++ trunk/ci/debbie/postgis_regress.sh 2017-12-18 16:52:50 UTC (rev 16160)
@@ -28,12 +28,14 @@
rm -rf ${WORKSPACE}/tmp/${POSTGIS_MAJOR_VERSION}_${POSTGIS_MINOR_VERSION}_pg${PG_VER}w${OS_BUILD}
#mkdir ${WORKSPACE}/tmp/
export PGIS_REG_TMPDIR=${WORKSPACE}/tmp/${POSTGIS_MAJOR_VERSION}_${POSTGIS_MINOR_VERSION}_pg${PG_VER}w${OS_BUILD}
+export POSTGIS_REGRESS_DB="postgis_reg" # FIXME: tweak to avoid clashes
+psql -c "DROP DATABASE IF EXISTS $POSTGIS_REGRESS_DB"
echo $PGPORT
echo ${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
## doesn't work for some reason - just hard-code to branches for now
-# if [[ $POSTGIS_MICRO_VERSION == *SVN* || $POSTGIS_MICRO_VERSION == *dev* ]]
+# if [[ $POSTGIS_MICRO_VERSION == *SVN* || $POSTGIS_MICRO_VERSION == *dev* ]]
# then
# export POSTGIS_SRC=${PROJECTS}/postgis/branches/${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
# else
@@ -59,7 +61,7 @@
--prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
make clean
## install so we can later test extension upgrade
-make
+make
if [ "$?" != "0" ]; then
exit $?
