[postgis-tickets] [PostGIS] #3739: ST_Within Not using index
trac at osgeo.org
Mon Jun 5 22:45:01 PDT 2017
Reporter: postgispaul | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Resolution: wontfix | Keywords:
Comment (by komzpa):
I've met the same thing and digged into estimators to understand what's
happening.
ANALYSE builds inexact histogram of data, with up to ~10000 cells. On the
scale of the world, it means they are ~300x300 km cells, with all the
cities falling into same cell.
When you join it, it multiplies a cell from table A by cell from table B
to get upper limit. Thus inside a city you get a squared number of
objects. When you're using unfiltered planet on both sides (with different
conditions) it leads to catastrophic overestimate of row count.
PostGIS estimator is unsuitable for planet-sized datasets unfortunately.
Workarounds I've used:
- kill postgis statistics using CLUSTER. Vacuum will come anyway and re-
collect it, so a short-term thing to use in scripts;
- bump work_mem to tremendously large values (20GB on my machine), so it
thinks the intermediate result will fit into it anyway;
- repeat the operator more times. Selectivity is still < 100%, each
repeat will multiply it by itself, getting it lower and lower.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3739#comment:29>
