[postgis-tickets] r15417 - shp2pgsql locale fixes are #3084, not #3048
Sandro Santilli
strk at kbt.io
Tue Jun 6 05:18:31 PDT 2017
Author: strk
Date: 2017-06-06 05:18:31 -0700 (Tue, 06 Jun 2017)
New Revision: 15417
trunk/NEWS
trunk/doc/release_notes.xml
Thanks Andreas Schild via
https://www.transifex.com/postgis/postgis/translate/#de/release_notesxmlpot/74993584/
Modified: trunk/NEWS
--- trunk/NEWS 2017-06-02 20:13:54 UTC (rev 15416)
+++ trunk/NEWS 2017-06-06 12:18:31 UTC (rev 15417)
@@ -9,11 +9,11 @@
- #3753, Gist penalty speed improvements for 2d and nd points
(Darafei Praliaskouski)
- #3677, ST_FrechetDistance (Shinichi Sugiyama)
* Bug Fixes *
- #3682, Boolean (FTLogical) should be 1 byte not 2 bytes
PostGIS 2.3.0
2016/09/26
@@ -288,7 +288,7 @@
max extent constraint
- #3018, GROUP BY geography sometimes returns duplicate rows
- #3020, ST_AddBand out-db bug where height using width value
- - #3048, shp2pgsql - illegal number format when specific system locale set
+ - #3084, shp2pgsql - illegal number format when specific system locale set
- #3061, Allow duplicate points in JSON, GML, GML ST_GeomFrom* functions
- #3086, ST_DumpValues() crashes backend on cleanup with invalid
band indexes
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml 2017-06-02 20:13:54 UTC (rev 15416)
+++ trunk/doc/release_notes.xml 2017-06-06 12:18:31 UTC (rev 15417)
@@ -6,16 +6,16 @@
<title>Release 2.3.0</title>
<para>Release date: 2016/09/26</para>
<para>This is a new feature release, with new functions, improved performance, all relevant bug fixes from PostGIS 2.2.3,and other goodies.</para>
<simplesect>
<title>Important / Breaking Changes</title>
<para>#3466, Casting from box3d to geometry now returns a 3D
- geometry (Julien Rouhaud of Dalibo)</para>
+ geometry (Julien Rouhaud of Dalibo)</para>
<para>#3396, ST_EstimatedExtent, throw WARNING instead of ERROR
(Regina Obe)</para>
</simplesect>
<simplesect>
<title>New Features</title>
<para>Add support for custom TOC in postgis_restore.pl
@@ -29,7 +29,7 @@
<para>#1758, ST_Normalize (Sandro Santilli)</para>
<para>#2236, shp2pgsql -d now emits "DROP TABLE IF EXISTS"</para>
<para>#2259, ST_VoronoiPolygons and ST_VoronoiLines (Dan Baston)</para>
- <para>#2841 and #2996, ST_MinimumBoundingRadius and new ST_MinimumBoundingCircle
+ <para>#2841 and #2996, ST_MinimumBoundingRadius and new ST_MinimumBoundingCircle
implementation using Welzl's algorithm (Dan Baston)</para>
<para>#2991, Enable ST_Transform to use PROJ.4 text (Mike Toews)</para>
<para>#3059, Allow passing per-dimension parameters in ST_Expand (Dan Baston)</para>
@@ -56,7 +56,7 @@
<para>#3613, Segmentize geography using equal length segments
(Hugo Mercier of Oslandia)</para>
</simplesect>
<simplesect>
<title>Bug Fixes</title>
<para>All relevant bug fixes from PostGIS 2.2.3</para>
@@ -74,9 +74,9 @@
<para>Make adding a line to topology interruptible (Sandro Santilli)</para>
<para>Documentation updates from Mike Toews</para>
</simplesect>
</sect1>
<sect1>
<title>Release 2.2.2</title>
<para>Release date: 2016/03/22</para>
@@ -97,7 +97,7 @@
<para>#3426, failing POINT EMPTY tests on fun architectures</para>
</simplesect>
</sect1>
<sect1>
<title>Release 2.2.1</title>
<para>Release date: 2016/01/06</para>
@@ -221,7 +221,7 @@
<para>#3159, do not force a bbox cache on ST_Affine</para>
<para>#3018, GROUP BY geography sometimes returns duplicate rows</para>
- <para>#3048, shp2pgsql - illegal number format when specific system locale set</para>
+ <para>#3084, shp2pgsql - illegal number format when specific system locale set</para>
<para>#3094, Malformed GeoJSON inputs crash backend</para>
<para>#3104, st_asgml introduces random characters in ID field</para>
<para>#3155, Remove liblwgeom.h on make uninstall</para>
