[postgis-tickets] r15424 - Mark functions that are currently stable or volatile (or missing parallel) as immutable parallel that should have been immutable parallel. First pass
Regina Obe lr at pcorp.us
Wed Jun 7 00:43:14 PDT 2017
Author: robe
Date: 2017-06-07 00:43:14 -0700 (Wed, 07 Jun 2017)
New Revision: 15424
   trunk/raster/rt_pg/rtpostgis.sql.in
More cleanup of missed schema qualification.
References #3769
Modified: trunk/raster/rt_pg/rtpostgis.sql.in
--- trunk/raster/rt_pg/rtpostgis.sql.in	2017-06-07 03:33:07 UTC (rev 15423)
+++ trunk/raster/rt_pg/rtpostgis.sql.in	2017-06-07 07:43:14 UTC (rev 15424)
@@ -122,7 +122,7 @@
 	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
 -- Availability: 2.0.0
--- Changed: 2.1.4 raised cost
+-- Changed: 2.1.4 raised cost
 CREATE OR REPLACE FUNCTION st_convexhull(raster)
     RETURNS geometry
     AS 'MODULE_PATHNAME','RASTER_convex_hull'
@@ -256,7 +256,7 @@
 		msg := msg || 'and extent of ' || extent;
 		IF
-			round(metadata.skewx::numeric, 10) <> round(0::numeric, 10) OR
+			round(metadata.skewx::numeric, 10) <> round(0::numeric, 10) OR
 			round(metadata.skewy::numeric, 10) <> round(0::numeric, 10)
 		THEN
 			msg := 'Skewed ' || overlay(msg placing 'r' from 1 for 1);
@@ -373,7 +373,7 @@
 	RETURNS raster
 	AS 'MODULE_PATHNAME', 'RASTER_copyBand'
-	LANGUAGE 'c' IMMUTABLE _PARALLEL;
+	LANGUAGE 'c' IMMUTABLE _PARALLEL;
 CREATE OR REPLACE FUNCTION st_addband(
 	torast raster,
@@ -569,7 +569,7 @@
 	sample_percent double precision DEFAULT 1
 	RETURNS summarystats
-	AS $$
+	AS $$
 	DECLARE
 		stats summarystats;
 	BEGIN
@@ -1795,7 +1795,7 @@
 					_colormap := '
 100%   0
   0% 254
-  nv 255
+  nv 255
 				WHEN 'pseudocolor' THEN
 					_colormap := '
@@ -2081,19 +2081,19 @@
 			options := array_append(options, 'QUALITY=' || quality2);
 		END IF;
-		RETURN st_asjpeg(st_band($1, $2), options);
+		RETURN @extschema at .st_asjpeg(st_band($1, $2), options);
 	END;
 	$$ LANGUAGE 'plpgsql' IMMUTABLE STRICT _PARALLEL;
 -- Cannot be strict as "options" can be NULL
 CREATE OR REPLACE FUNCTION st_asjpeg(rast raster, nband int, options text[] DEFAULT NULL)
 	RETURNS bytea
-	AS $$ SELECT st_asjpeg(st_band($1, $2), $3) $$
+	AS $$ SELECT @extschema at .st_asjpeg(st_band($1, $2), $3) $$
 	LANGUAGE 'sql' IMMUTABLE _PARALLEL;
 CREATE OR REPLACE FUNCTION st_asjpeg(rast raster, nband int, quality int)
 	RETURNS bytea
-	AS $$ SELECT st_asjpeg($1, ARRAY[$2], $3) $$
+	AS $$ SELECT @extschema at .st_asjpeg($1, ARRAY[$2], $3) $$
 	LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
@@ -2118,8 +2118,8 @@
 		-- PNG allows 1, 3 or 4 bands
 		IF num_bands <> 1 AND num_bands <> 3 AND num_bands <> 4 THEN
 			RAISE NOTICE 'The PNG format only permits one, three or four bands.  The first band will be used.';
-			rast2 := st_band($1, ARRAY[1]);
-			num_bands := st_numbands(rast2);
+			rast2 := @extschema at .st_band($1, ARRAY[1]);
+			num_bands := @extschema at .st_numbands(rast2);
 		ELSE
 			rast2 := rast;
 		END IF;
@@ -2132,14 +2132,14 @@
 			END IF;
 		END LOOP;
-		RETURN st_asgdalraster(rast2, 'PNG', $2, NULL);
+		RETURN @extschema at .st_asgdalraster(rast2, 'PNG', $2, NULL);
 	END;
 	$$ LANGUAGE 'plpgsql' IMMUTABLE _PARALLEL;
 CREATE OR REPLACE FUNCTION st_aspng(rast raster, nbands int[], options text[] DEFAULT NULL)
 	RETURNS bytea
-	AS $$ SELECT st_aspng(st_band($1, $2), $3) $$
+	AS $$ SELECT @extschema at .st_aspng(st_band($1, $2), $3) $$
 CREATE OR REPLACE FUNCTION st_aspng(rast raster, nbands int[], compression int)
@@ -2161,18 +2161,18 @@
 			options := array_append(options, 'ZLEVEL=' || compression2);
 		END IF;
-		RETURN st_aspng(st_band($1, $2), options);
+		RETURN @extschema at .st_aspng(st_band($1, $2), options);
 	END;
 CREATE OR REPLACE FUNCTION st_aspng(rast raster, nband int, options text[] DEFAULT NULL)
 	RETURNS bytea
 CREATE OR REPLACE FUNCTION st_aspng(rast raster, nband int, compression int)
 	RETURNS bytea
-	AS $$ SELECT st_aspng($1, ARRAY[$2], $3) $$
+	AS $$ SELECT @extschema at .st_aspng($1, ARRAY[$2], $3) $$
@@ -2193,7 +2193,7 @@
 	RETURNS raster
 	AS 'MODULE_PATHNAME', 'RASTER_asRaster'
-	LANGUAGE 'c' STABLE;
 CREATE OR REPLACE FUNCTION st_asraster(
 	geom geometry,
@@ -2207,7 +2207,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_asraster($1, $2, $3, NULL, NULL, $6, $7, $8, NULL, NULL, $4, $5, $9, $10, $11) $$
-	LANGUAGE 'sql' STABLE;
+	LANGUAGE 'sql' IMMUTABLE _PARALLEL;
 	geom geometry,
@@ -2221,7 +2221,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_asraster($1, $2, $3, NULL, NULL, $4, $5, $6, $7, $8, NULL, NULL,	$9, $10, $11) $$
 	geom geometry,
@@ -2235,7 +2235,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_asraster($1, NULL, NULL, $2, $3, $6, $7, $8, NULL, NULL, $4, $5, $9, $10, $11) $$
 	geom geometry,
@@ -2249,7 +2249,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_asraster($1, NULL, NULL, $2, $3, $4, $5, $6, $7, $8, NULL, NULL,	$9, $10, $11) $$
 	geom geometry,
@@ -2263,7 +2263,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_asraster($1, $2, $3, NULL, NULL, ARRAY[$6]::text[], ARRAY[$7]::double precision[], ARRAY[$8]::double precision[], NULL, NULL, $4, $5, $9, $10, $11) $$
 	geom geometry,
@@ -2277,7 +2277,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_asraster($1, $2, $3, NULL, NULL, ARRAY[$4]::text[], ARRAY[$5]::double precision[], ARRAY[$6]::double precision[], $7, $8, NULL, NULL, $9, $10, $11) $$
 	geom geometry,
@@ -2291,7 +2291,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_asraster($1, NULL, NULL, $2, $3, ARRAY[$6]::text[], ARRAY[$7]::double precision[], ARRAY[$8]::double precision[], NULL, NULL, $4, $5, $9, $10, $11) $$
 	geom geometry,
@@ -2305,7 +2305,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_asraster($1, NULL, NULL, $2, $3, ARRAY[$4]::text[], ARRAY[$5]::double precision[], ARRAY[$6]::double precision[], $7, $8, NULL, NULL,$9, $10, $11) $$
 	geom geometry,
@@ -2343,7 +2343,7 @@
 		RETURN @extschema at ._ST_asraster(g, scale_x, scale_y, NULL, NULL, $3, $4, $5, NULL, NULL, ul_x, ul_y, skew_x, skew_y, $6);
 	END;
-	$$ LANGUAGE 'plpgsql' STABLE;
+	$$ LANGUAGE 'plpgsql' IMMUTABLE _PARALLEL;
 	geom geometry,
@@ -2355,7 +2355,7 @@
 	RETURNS raster
 	AS $$ SELECT  @extschema at .ST_AsRaster($1, $2, ARRAY[$3]::text[], ARRAY[$4]::double precision[], ARRAY[$5]::double precision[], $6) $$
 -- ST_GDALWarp
@@ -2373,7 +2373,7 @@
 	RETURNS raster
 	AS 'MODULE_PATHNAME', 'RASTER_GDALWarp'
 -- ST_Resample
@@ -2387,7 +2387,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_gdalwarp($1, $8,	$9, NULL, $2, $3, $4, $5, $6, $7) $$
 CREATE OR REPLACE FUNCTION st_resample(
 	rast raster,
@@ -2398,7 +2398,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_gdalwarp($1, $8,	$9, NULL, NULL, NULL, $4, $5, $6, $7, $2, $3) $$
 	rast raster,
@@ -2442,7 +2442,7 @@
 		RETURN @extschema at ._ST_gdalwarp($1, $3, $4, NULL, _scalex, _scaley, _gridx, _gridy, _skewx, _skewy, _dimx, _dimy);
 	END;
-	$$ LANGUAGE 'plpgsql' STABLE STRICT;
+	$$ LANGUAGE 'plpgsql' IMMUTABLE STRICT _PARALLEL;
 	rast raster,
@@ -2452,8 +2452,8 @@
 	maxerr double precision DEFAULT 0.125
 	RETURNS raster
-	AS $$ SELECT st_resample($1, $2, $4, $5, $3) $$
-	LANGUAGE 'sql' STABLE STRICT;
+	AS $$ SELECT @extschema at .st_resample($1, $2, $4, $5, $3) $$
+	LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
 -- ST_Transform
@@ -2461,20 +2461,20 @@
 CREATE OR REPLACE FUNCTION st_transform(rast raster, srid integer, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125, scalex double precision DEFAULT 0, scaley double precision DEFAULT 0)
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_gdalwarp($1, $3, $4, $2, $5, $6) $$
 CREATE OR REPLACE FUNCTION st_transform(rast raster, srid integer, scalex double precision, scaley double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125)
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_gdalwarp($1, $5, $6, $2, $3, $4) $$
 CREATE OR REPLACE FUNCTION st_transform(rast raster, srid integer, scalexy double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125)
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_gdalwarp($1, $4, $5, $2, $3, $3) $$
-	rast raster,
+	rast raster,
 	alignto raster,
@@ -2493,7 +2493,7 @@
 		RETURN @extschema at ._ST_gdalwarp($1, $3, $4, _srid, _scalex, _scaley, _gridx, _gridy, _skewx, _skewy, NULL, NULL);
 	END;
 -- ST_Rescale
@@ -2501,12 +2501,12 @@
 CREATE OR REPLACE FUNCTION st_rescale(rast raster, scalex double precision, scaley double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125)
 	RETURNS raster
 	AS $$ SELECT  @extschema at ._ST_GdalWarp($1, $4, $5, NULL, $2, $3) $$
 CREATE OR REPLACE FUNCTION st_rescale(rast raster, scalexy double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125)
 	RETURNS raster
 	AS $$ SELECT  @extschema at ._ST_GdalWarp($1, $3, $4, NULL, $2, $2) $$
 -- ST_Reskew
@@ -2514,12 +2514,12 @@
 CREATE OR REPLACE FUNCTION st_reskew(rast raster, skewx double precision, skewy double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125)
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_GdalWarp($1, $4, $5, NULL, 0, 0, NULL, NULL, $2, $3) $$
 CREATE OR REPLACE FUNCTION st_reskew(rast raster, skewxy double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125)
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_GdalWarp($1, $3, $4, NULL, 0, 0, NULL, NULL, $2, $2) $$
 -- ST_SnapToGrid
@@ -2532,7 +2532,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_GdalWarp($1, $4, $5, NULL, $6, $7, $2, $3) $$
 CREATE OR REPLACE FUNCTION st_snaptogrid(
 	rast raster,
@@ -2542,7 +2542,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_gdalwarp($1, $6, $7, NULL, $4, $5, $2, $3) $$
 	rast raster,
@@ -2552,7 +2552,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_gdalwarp($1, $5, $6, NULL, $4, $4, $2, $3) $$
 -- ST_Resize
@@ -2637,7 +2637,7 @@
 			whi[1], whi[2]
 	END;
 CREATE OR REPLACE FUNCTION st_resize(
 	rast raster,
@@ -2646,7 +2646,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_gdalwarp($1, $4, $5, NULL, NULL, NULL, NULL, NULL, NULL, NULL, abs($2), abs($3)) $$
 	rast raster,
@@ -2686,7 +2686,7 @@
 			_width, _height
 	END;
 -- One Raster ST_MapAlgebra
@@ -2705,7 +2705,7 @@
         nodataval double precision DEFAULT NULL)
     RETURNS raster
     AS $$ SELECT @extschema at .ST_mapalgebraexpr($1, 1, $2, $3, $4) $$
-    LANGUAGE 'sql';
 -- All arguments supplied, use the C implementation.
 CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, band integer,
@@ -2719,48 +2719,48 @@
         pixeltype text, onerastuserfunc regprocedure)
     RETURNS raster
     AS $$ SELECT @extschema at .ST_mapalgebrafct($1, $2, $3, $4, NULL) $$
-    LANGUAGE 'sql';
 -- Variant 2: missing pixeltype; default to pixeltype of rast
         onerastuserfunc regprocedure, variadic args text[])
     RETURNS raster
     AS $$ SELECT @extschema at .ST_mapalgebrafct($1, $2, NULL, $3, VARIADIC $4) $$
-    LANGUAGE 'sql';
 -- Variant 3: missing pixeltype and user args; default to pixeltype of rast
     RETURNS raster
     AS $$ SELECT @extschema at .ST_mapalgebrafct($1, $2, NULL, $3, NULL) $$
-    LANGUAGE 'sql';
 -- Variant 4: missing band; default to band 1
 CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, pixeltype text,
     RETURNS raster
     AS $$ SELECT @extschema at .ST_mapalgebrafct($1, 1, $2, $3, VARIADIC $4) $$
-    LANGUAGE 'sql';
 -- Variant 5: missing band and user args; default to band 1
     RETURNS raster
     AS $$ SELECT @extschema at .ST_mapalgebrafct($1, 1, $2, $3, NULL) $$
-    LANGUAGE 'sql';
 -- Variant 6: missing band, and pixeltype; default to band 1, pixeltype of rast.
 CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, onerastuserfunc regprocedure,
     RETURNS raster
     AS $$ SELECT @extschema at .ST_mapalgebrafct($1, 1, NULL, $2, VARIADIC $3) $$
-    LANGUAGE 'sql';
 -- Variant 7: missing band, pixeltype, and user args; default to band 1, pixeltype of rast.
 CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, onerastuserfunc regprocedure)
     RETURNS raster
     AS $$ SELECT @extschema at .ST_mapalgebrafct($1, 1, NULL, $2, NULL) $$
-    LANGUAGE 'sql';
 -- Two Raster ST_MapAlgebra
@@ -2775,7 +2775,7 @@
 	RETURNS raster
 	AS 'MODULE_PATHNAME', 'RASTER_mapAlgebra2'
 CREATE OR REPLACE FUNCTION st_mapalgebraexpr(
 	rast1 raster,
@@ -2787,7 +2787,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at .ST_mapalgebraexpr($1, 1, $2, 1, $3, $4, $5, $6, $7, $8) $$
 	rast1 raster, band1 integer,
@@ -2798,7 +2798,7 @@
 	RETURNS raster
 	rast1 raster,
@@ -2809,7 +2809,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at .ST_mapalgebrafct($1, 1, $2, 1, $3, $4, $5, VARIADIC $6) $$
 -- Neighborhood single raster map algebra
@@ -3003,7 +3003,7 @@
 	RETURNS raster
 	AS 'MODULE_PATHNAME', 'RASTER_nMapAlgebra'
@@ -3017,7 +3017,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_MapAlgebra($1, $2, $3, $6, $7, $4, $5,NULL::double precision [],NULL::boolean, VARIADIC $8) $$
 CREATE OR REPLACE FUNCTION st_mapalgebra(
 	rast raster, nband int[],
@@ -3053,7 +3053,7 @@
 		RETURN @extschema at ._ST_MapAlgebra(argset, $3, $4, $7, $8, $5, $6,NULL::double precision [],NULL::boolean, VARIADIC $9);
 	END;
@@ -3065,7 +3065,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_MapAlgebra(ARRAY[ROW($1, $2)]::rastbandarg[], $3, $4, $7, $8, $5, $6,NULL::double precision [],NULL::boolean, VARIADIC $9) $$
 	rast1 raster, nband1 int,
@@ -3078,7 +3078,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_MapAlgebra(ARRAY[ROW($1, $2), ROW($3, $4)]::rastbandarg[], $5, $6, $9, $10, $7, $8,NULL::double precision [],NULL::boolean, VARIADIC $11) $$
@@ -3091,7 +3091,7 @@
 	RETURNS raster
 	AS $$
 	select @extschema at ._ST_mapalgebra(ARRAY[ROW($1,$2)]::rastbandarg[],$3,$6,NULL::integer,NULL::integer,$7,$8,$4,$5,VARIADIC $9)
-	$$ LANGUAGE 'sql' STABLE;
+	$$ LANGUAGE 'sql' IMMUTABLE _PARALLEL;
 -- 1 or 2-Raster ST_MapAlgebra with expressions
@@ -3106,7 +3106,7 @@
 	RETURNS raster
 	AS 'MODULE_PATHNAME', 'RASTER_nMapAlgebraExpr'
 	rast raster, nband integer,
@@ -3115,7 +3115,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_mapalgebra(ARRAY[ROW($1, $2)]::rastbandarg[], $4, $3, 'FIRST', $5::text) $$
 	rast raster,
@@ -3124,7 +3124,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at .ST_mapalgebra($1, 1, $2, $3, $4) $$
@@ -3136,7 +3136,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at ._ST_mapalgebra(ARRAY[ROW($1, $2), ROW($3, $4)]::rastbandarg[], $5, $6, $7, $8, $9, $10) $$
 	rast1 raster,
@@ -3148,7 +3148,7 @@
 	RETURNS raster
 	AS $$ SELECT @extschema at .ST_mapalgebra($1, 1, $2, 1, $3, $4, $5, $6, $7, $8) $$
 -- ST_MapAlgebra callback functions
@@ -4372,7 +4372,7 @@
 		mean := (Z1 + Z2 + Z3 + Z4 + Z6 + Z7 + Z8 + Z9)/8;
 		tpi := Z5-mean;
 		return tpi;
 	END;
@@ -4654,8 +4654,8 @@
 		Z9 := _value[z][3][3];
 		tri := ( abs(Z1 - Z5 ) + abs( Z2 - Z5 ) + abs( Z3 - Z5 ) + abs( Z4 - Z5 ) + abs( Z6 - Z5 ) + abs( Z7 - Z5 ) + abs( Z8 - Z5 ) + abs ( Z9 - Z5 )) / 8;
-		return tri;
+		return tri;
 	END;
@@ -4977,7 +4977,7 @@
 CREATE OR REPLACE FUNCTION st_setgeotransform(rast raster,
-    imag double precision,
+    imag double precision,
     jmag double precision,
     theta_i double precision,
     theta_ij double precision,
@@ -5397,7 +5397,7 @@
 -- ST_WorldToRasterCoordX(rast raster, pt geometry)
--- Returns the pixel column and row covering the provided point geometry.
+-- Returns the pixel column and row covering the provided point geometry.
 -- This function works even if the point is outside the raster extent.
 CREATE OR REPLACE FUNCTION st_worldtorastercoord(
@@ -5752,7 +5752,7 @@
     RETURNS bool
     AS 'select $1::geometry OPERATOR(@extschema at .&&) $2'
 -- geometry/raster functions
@@ -5772,7 +5772,7 @@
     RETURNS bool
     AS 'select $1 OPERATOR(@extschema at .&&) $2::geometry'
 --  GiST index OPERATORs
@@ -6057,7 +6057,7 @@
 		-- edge tile
 		-- edge tile may have same size as inner tile
-		IF
+		IF
 			(_rastmeta.width = tilewidth) AND
 			(_rastmeta.height = tileheight)
 		THEN
@@ -6463,7 +6463,7 @@
 		newnodata1 := coalesce(nodataval[1], ST_BandNodataValue(rast1, band1), ST_MinPossibleValue(@extschema at .ST_BandPixelType(rast1, band1)));
 		newnodata2 := coalesce(nodataval[2], ST_BandNodataValue(rast2, band2), ST_MinPossibleValue(@extschema at .ST_BandPixelType(rast2, band2)));
 		_returnband := upper(returnband);
 		rtn := NULL;
@@ -6496,7 +6496,7 @@
 	RETURNS raster AS
 	$$ SELECT st_intersection($1, $2, $3, $4, $5, ARRAY[$6, $6]) $$
 CREATE OR REPLACE FUNCTION st_intersection(
 	rast1 raster, band1 int,
@@ -6505,7 +6505,7 @@
 	RETURNS raster AS
 	$$ SELECT st_intersection($1, $2, $3, $4, 'BOTH', $5) $$
@@ -6514,7 +6514,7 @@
 	RETURNS raster AS
 	$$ SELECT st_intersection($1, $2, $3, $4, 'BOTH', ARRAY[$5, $5]) $$
 -- Variants without band number
@@ -6525,7 +6525,7 @@
 	RETURNS raster AS
 	$$ SELECT st_intersection($1, 1, $2, 1, $3, $4) $$
 	rast1 raster,
@@ -6535,7 +6535,7 @@
 	RETURNS raster AS
 	$$ SELECT st_intersection($1, 1, $2, 1, $3, ARRAY[$4, $4]) $$
 	rast1 raster,
@@ -6544,7 +6544,7 @@
 	RETURNS raster AS
 	$$ SELECT st_intersection($1, 1, $2, 1, 'BOTH', $3) $$
 	rast1 raster,
@@ -6553,7 +6553,7 @@
 	RETURNS raster AS
 	$$ SELECT st_intersection($1, 1, $2, 1, 'BOTH', ARRAY[$3, $3]) $$
 -- ST_Union aggregate
@@ -6988,10 +6988,10 @@
 		AND s.connamespace = n.oid
 		AND s.conrelid = c.oid
 		AND a.attnum = ANY (s.conkey)
-		AND s.consrc LIKE '%st_scale' || $4 || '(% = %')
+		AND s.consrc LIKE '%st_scale' || $4 || '(% = %')
 -- if it is a comma separated list of two numbers then need to use round
-   SELECT CASE WHEN split_part(c.val,',', 2) > ''
-        THEN round( split_part(c.val, ',',1)::numeric, split_part(c.val,',',2)::integer )::float8
+   SELECT CASE WHEN split_part(c.val,',', 2) > ''
+        THEN round( split_part(c.val, ',',1)::numeric, split_part(c.val,',',2)::integer )::float8
         ELSE c.val::float8 END
         FROM c;
 	$$ LANGUAGE sql STABLE STRICT
@@ -7174,7 +7174,7 @@
             || fqtn
             || ' LIMIT 1;';
     EXECUTE sql INTO srid;
 		cn := 'enforce_max_extent_' || $3;
 		sql := 'SELECT @extschema at .st_ashexewkb( @extschema at .st_setsrid( @extschema at .st_extent( @extschema at .st_envelope('
@@ -7323,7 +7323,7 @@
 			AND s.conexclop[1] = op.oid
 			AND op.oprname = '=';
-		RETURN  @extschema at ._drop_raster_constraint($1, $2, cn);
+		RETURN  @extschema at ._drop_raster_constraint($1, $2, cn);
 	END;
 	$$ LANGUAGE 'plpgsql' VOLATILE STRICT
 	COST 100;
@@ -7609,7 +7609,7 @@
 CREATE OR REPLACE FUNCTION _raster_constraint_nodata_values(rast raster)
 	RETURNS numeric[] AS
 	$$ SELECT array_agg(round(nodatavalue::numeric, 10))::numeric[] FROM @extschema at .ST_BandMetaData($1, ARRAY[]::int[]); $$
 CREATE OR REPLACE FUNCTION _add_raster_constraint_nodata_values(rastschema name, rasttable name, rastcolumn name)
 	RETURNS boolean AS $$
@@ -7696,7 +7696,7 @@
 CREATE OR REPLACE FUNCTION _raster_constraint_out_db(rast raster)
 	RETURNS boolean[] AS
 	$$ SELECT array_agg(isoutdb)::boolean[] FROM @extschema at .ST_BandMetaData($1, ARRAY[]::int[]); $$
 CREATE OR REPLACE FUNCTION _add_raster_constraint_out_db(rastschema name, rasttable name, rastcolumn name)
