[postgis-tickets] [PostGIS] #2974: ST_ConvexHull is uninterruptible
PostGIS trac at osgeo.org
Fri Jun 9 06:38:09 PDT 2017
  Reporter:  strk     |      Owner:  strk
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS GEOS
 Component:  postgis  |    Version:  2.1.x
Resolution:  fixed    |   Keywords:
Comment (by robe):
 I don't think so and probably wouldn't be a good idea until we make the
 interruption tests less fragile.  As it is I have it turned off on debbie
 and winnie.  We should probably turn it off on dronie as well since it
 errors out a lot because of them.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2974#comment:9>
