[postgis-tickets] [PostGIS] #3772: ST_CurveToLine symmetric output
trac at osgeo.org
Tue Jun 13 01:39:20 PDT 2017
Reporter: strk | Owner: strk
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Keywords: |
The Current ST_CurveToLine function does not make any effort to balance
the resulting segments so that the length of first and last segments are
equal.
Rather, segments from the start try to be as long as needed to conver a
quarter circle by as many segments as segments_per_qtr_circle argument
requests.
This ticket is to allow for requesting a symmetric output instead, that is
balancing the length of last segment so that it is the same of the first
segment.
See also #2464
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3772>
