[postgis-tickets] r15436 - Style only change: remove trailing blanks
Sandro Santilli
strk at kbt.io
Mon Jun 19 13:37:00 PDT 2017
Author: strk
Date: 2017-06-19 13:37:00 -0700 (Mon, 19 Jun 2017)
New Revision: 15436
branches/2.3/postgis/Makefile.in
Modified: branches/2.3/postgis/Makefile.in
--- branches/2.3/postgis/Makefile.in 2017-06-19 20:35:21 UTC (rev 15435)
+++ branches/2.3/postgis/Makefile.in 2017-06-19 20:37:00 UTC (rev 15436)
@@ -27,7 +27,7 @@
MODULEDIR=contrib/$(MODULE_big)
# Files to be copied to the contrib/ directory
-SQL_built=postgis.sql postgis_for_extension.sql uninstall_postgis.sql postgis_upgrade.sql postgis_upgrade_for_extension.sql postgis_proc_set_search_path.sql legacy.sql uninstall_legacy.sql legacy_minimal.sql legacy_gist.sql
+SQL_built=postgis.sql postgis_for_extension.sql uninstall_postgis.sql postgis_upgrade.sql postgis_upgrade_for_extension.sql postgis_proc_set_search_path.sql legacy.sql uninstall_legacy.sql legacy_minimal.sql legacy_gist.sql
DATA=../spatial_ref_sys.sql
# SQL objects (files requiring pre-processing)
@@ -126,7 +126,7 @@
postgis_upgrade.sql.in \
postgis_upgrade.sql \
sfcgal_upgrade.sql.in \
- sfcgal_upgrade.sql
+ sfcgal_upgrade.sql
# PGXS information
PG_CONFIG = @PG_CONFIG@
@@ -176,10 +176,10 @@
%.sql: %.sql.in
$(SQLPP) -I../libpgcommon $< | grep -v '^#' | \
$(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g;s'@extschema@\.''g" > $@
postgis_upgrade_for_extension.sql: postgis_drop_before.sql postgis_upgrade_for_extension.sql.in postgis_drop_after.sql
cat $^ >> $@
postgis_for_extension.sql: postgis.sql.in
$(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g" > $@
@@ -187,10 +187,10 @@
#this is redundant but trying to fold in with extension just hangs
postgis_upgrade.sql.in: postgis.sql ../utils/postgis_proc_upgrade.pl
$(PERL) ../utils/postgis_proc_upgrade.pl $< UNUSED > $@
postgis_upgrade_for_extension.sql.in: postgis_for_extension.sql ../utils/postgis_proc_upgrade.pl
postgis_proc_set_search_path.sql: postgis.sql ../utils/postgis_proc_set_search_path.pl
$(PERL) ../utils/postgis_proc_set_search_path.pl $< UNUSED > $@
@@ -199,7 +199,7 @@
cat $^ >> $@
echo "COMMIT;" >> $@
-sfcgal_upgrade.sql.in: sfcgal.sql ../utils/postgis_proc_upgrade.pl
+sfcgal_upgrade.sql.in: sfcgal.sql ../utils/postgis_proc_upgrade.pl
sfcgal_upgrade.sql: sfcgal_upgrade.sql.in postgis_drop_after.sql
