[postgis-tickets] [PostGIS] #3777: POINT EMPTY, POINT 0 0 anomaly
trac at osgeo.org
Wed Jun 21 14:59:29 PDT 2017
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by robe):
We must have had this problem for sometime. PostGIS 1.5.5 is doing
something different as well when change order of items. Check this out:
SELECT ST_AsText(geom) txt
FROM (
SELECT 'GEOMETRYCOLLECTION EMPTY'::geometry geom
UNION
SELECT 'POINT EMPTY'::geometry geom
UNION
SELECT 'POINT(0 0)'::geometry geom
UNION
UNION
UNION
SELECT 'POINT(0 1)'::geometry geom
UNION
SELECT 'LINESTRING(0 0,0 1)'::geometry geom
) foo;
In 2.3.2 and 2.4.0dev
txt
POINT(0 0)
POINT(0 0)
POINT EMPTY
POINT(0 0)
LINESTRING(0 0,0 1)
POINT(0 1)
(7 rows)
In 1.5.5
txt
POINT(0 0)
LINESTRING(0 0,0 1)
POINT(0 1)
(3 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3777#comment:6>
