[postgis-tickets] r15441 - Escape double quotes issue in pgsql2shp
Regina Obe
lr at pcorp.us
Thu Jun 22 22:13:22 PDT 2017
Author: robe
Date: 2017-06-22 22:13:22 -0700 (Thu, 22 Jun 2017)
New Revision: 15441
trunk/loader/pgsql2shp-core.c
trunk/loader/pgsql2shp-core.h
trunk/regress/dumper/realtable-pre.sql
trunk/regress/dumper/realtable_expected.dbf
Include test for boolean and quotes
References #3701 for PostGIS 2.4 (trunk)
Modified: trunk/loader/pgsql2shp-core.c
--- trunk/loader/pgsql2shp-core.c 2017-06-21 11:23:11 UTC (rev 15440)
+++ trunk/loader/pgsql2shp-core.c 2017-06-23 05:13:22 UTC (rev 15441)
@@ -15,6 +15,7 @@
* Original Author: Jeff Lounsbury <jeffloun at refractions.net>
* Contributions by: Sandro Santilli <strk at keybit.bet>
* Enhanced by: Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk>
+ * Enhanced by: Regina Obe <lr at pcorp.us>
@@ -882,14 +883,14 @@
if (state->schema)
query = malloc(150 + 4 * strlen(state->geo_col_name) + strlen(state->schema) + strlen(state->table));
sprintf(query, "SELECT count(\"%s\"), max(ST_zmflag(\"%s\"::geometry)), geometrytype(\"%s\"::geometry) FROM \"%s\".\"%s\" GROUP BY geometrytype(\"%s\"::geometry)",
state->geo_col_name, state->geo_col_name, state->geo_col_name, state->schema, state->table, state->geo_col_name);
else
query = malloc(150 + 4 * strlen(state->geo_col_name) + strlen(state->table));
sprintf(query, "SELECT count(\"%s\"), max(ST_zmflag(\"%s\"::geometry)), geometrytype(\"%s\"::geometry) FROM \"%s\" GROUP BY geometrytype(\"%s\"::geometry)",
state->geo_col_name, state->geo_col_name, state->geo_col_name, state->table, state->geo_col_name);
@@ -900,7 +901,7 @@
if (state->schema)
query = malloc(40 + strlen(state->schema) + strlen(state->table));
sprintf(query, "SELECT count(1) FROM \"%s\".\"%s\"", state->schema, state->table);
else
@@ -973,7 +974,7 @@
typemismatch = 1;
else
typefound = MULTILINETYPE;
- break;
+ break;
case MULTIPOLYGONTYPE:
if (typefound != MULTIPOLYGONTYPE && typefound != POLYGONTYPE)
@@ -1043,11 +1044,11 @@
case 'z':
state->outshptype = SHPT_POINTZ;
break;
case 'm':
state->outshptype = SHPT_POINTM;
break;
default:
state->outshptype = SHPT_POINT;
@@ -1059,11 +1060,11 @@
case 'z':
state->outshptype = SHPT_MULTIPOINTZ;
break;
case 'm':
state->outshptype = SHPT_MULTIPOINTM;
break;
default:
state->outshptype = SHPT_MULTIPOINT;
@@ -1076,11 +1077,11 @@
case 'z':
state->outshptype = SHPT_ARCZ;
break;
case 'm':
state->outshptype = SHPT_ARCM;
break;
default:
state->outshptype = SHPT_ARC;
@@ -1093,11 +1094,11 @@
case 'z':
state->outshptype = SHPT_POLYGONZ;
break;
case 'm':
state->outshptype = SHPT_POLYGONM;
break;
default:
state->outshptype = SHPT_POLYGON;
@@ -1167,7 +1168,7 @@
state->pgfieldnames = NULL;
state->big_endian = is_bigendian();
colmap_init(&state->column_map);
return state;
@@ -1177,7 +1178,7 @@
char *connstring;
int connlen;
connlen = 64 +
(conn->host ? strlen(conn->host) : 0) + (conn->port ? strlen(conn->port) : 0) +
(conn->username ? strlen(conn->username) : 0) + (conn->password ? strlen(conn->password) : 0) +
@@ -1205,7 +1206,7 @@
if (conn->password)
strcat(connstring, " password='");
strcat(connstring, conn->password);
strcat(connstring, "'");
@@ -1265,7 +1266,7 @@
snprintf(state->message, SHPDUMPERMSGLEN, "%s", PQresultErrorMessage(res));
PQclear(res);
free(connstring);
- return SHPDUMPERERR;
+ return SHPDUMPERERR;
tmpvalue = PQgetvalue(res, 0, 0);
@@ -1280,7 +1281,7 @@
snprintf(state->message, SHPDUMPERMSGLEN, _("Error looking up geometry oid: %s"), PQresultErrorMessage(res));
PQclear(res);
free(connstring);
if (PQntuples(res) > 0)
@@ -1305,7 +1306,7 @@
snprintf(state->message, SHPDUMPERMSGLEN, _("Error looking up geography oid: %s"), PQresultErrorMessage(res));
PQclear(res);
free(connstring);
@@ -1341,7 +1342,7 @@
&state->column_map, state->message, SHPDUMPERMSGLEN);
if (!ret) return SHPDUMPERERR;
/* If a user-defined query has been specified, create and point the state to our new table */
if (state->config->usrquery)
@@ -1434,7 +1435,7 @@
state->dbf = DBFCreateEx(state->shp_file, "UTF-8");
if (!state->dbf)
snprintf(state->message, SHPDUMPERMSGLEN, _("Could not create dbf file %s"), state->shp_file);
@@ -1485,7 +1486,7 @@
if (!state->config->geo_col_name || !strcmp(state->config->geo_col_name, pgfieldname))
dbffieldtype = 9;
state->geo_col_name = strdup(pgfieldname);
@@ -1534,7 +1535,7 @@
dbffieldname[10] = '\0';
* make sure the fields all have unique names,
@@ -1748,14 +1749,14 @@
snprintf(buf, 256, _("Warning: values of field '%s' exceeding maximum dbf field width (%d) "
"will be truncated.\n"), dbffieldname, MAX_DBF_FIELD_SIZE);
strncat(state->message, buf, SHPDUMPERMSGLEN - strlen(state->message));
- dbffieldsize = MAX_DBF_FIELD_SIZE;
+ dbffieldsize = MAX_DBF_FIELD_SIZE;
ret = SHPDUMPERWARN;
LWDEBUGF(3, "DBF FIELD_NAME: %s, SIZE: %d\n", dbffieldname, dbffieldsize);
if (dbffieldtype != 9)
/* Add the field to the DBF file */
@@ -1765,14 +1766,14 @@
/* Add the field information to our field arrays */
state->dbffieldnames[state->fieldcount] = dbffieldname;
state->dbffieldtypes[state->fieldcount] = dbffieldtype;
state->pgfieldnames[state->fieldcount] = pgfieldname;
state->pgfieldlens[state->fieldcount] = pgfieldlen;
state->pgfieldtypmods[state->fieldcount] = pgtypmod;
state->fieldcount++;
@@ -1804,7 +1805,7 @@
state->shp = NULL;
@@ -1819,16 +1820,17 @@
/* Now we have the complete list of fieldnames, let's generate the SQL query. First let's make sure
we reserve enough space for tables with lots of columns */
j = 0;
+ /*TODO: this really should be rewritten to use stringbuffer */
for (i = 0; i < state->fieldcount; i++)
- j += strlen(state->pgfieldnames[i] + 2); /* Add 2 for leading and trailing quotes */
+ j += strlen( state->pgfieldnames[i]) + 10; /*add extra space for the quotes to quote identify and any embedded quotes that may need escaping */
state->main_scan_query = malloc(1024 + j);
sprintf(state->main_scan_query, "DECLARE cur ");
if (state->config->binary)
strcat(state->main_scan_query, "BINARY ");
@@ -1840,11 +1842,11 @@
/* Comma-separated column names */
if (i > 0)
strcat(state->main_scan_query, ",");
- sprintf(buf, "\"%s\"::text", state->pgfieldnames[i]);
+ sprintf(buf, "%s::text", quote_identifier(state->pgfieldnames[i]) ) ;
else
- sprintf(buf, "\"%s\"", state->pgfieldnames[i]);
+ sprintf(buf, "%s", quote_identifier(state->pgfieldnames[i]) );
strcat(state->main_scan_query, buf);
@@ -1855,29 +1857,29 @@
/* If this is the (only) column, no need for the initial comma */
if (state->fieldcount > 0)
if (state->big_endian)
if (state->pgis_major_version > 0)
- sprintf(buf, "ST_asEWKB(ST_SetSRID(\"%s\"::geometry, 0), 'XDR') AS _geoX", state->geo_col_name);
+ sprintf(buf, "ST_asEWKB(ST_SetSRID(%s::geometry, 0), 'XDR') AS _geoX", quote_identifier(state->geo_col_name) );
else
- sprintf(buf, "asbinary(\"%s\"::geometry, 'XDR') AS _geoX",
- state->geo_col_name);
+ sprintf(buf, "asbinary(%s::geometry, 'XDR') AS _geoX",
+ quote_identifier(state->geo_col_name) );
else /* little_endian */
- sprintf(buf, "ST_AsEWKB(ST_SetSRID(\"%s\"::geometry, 0), 'NDR') AS _geoX", state->geo_col_name);
+ sprintf(buf, "ST_AsEWKB(ST_SetSRID(%s::geometry, 0), 'NDR') AS _geoX", quote_identifier(state->geo_col_name) ) ;
else
- sprintf(buf, "asbinary(\"%s\"::geometry, 'NDR') AS _geoX",
+ sprintf(buf, "asbinary(%s::geometry, 'NDR') AS _geoX",
@@ -2081,43 +2083,43 @@
PQclear(state->fetchres);
/* Call the relevant method depending upon the geometry type */
LWDEBUGF(4, "geomtype: %s\n", lwtype_name(lwgeom->type));
switch (lwgeom->type)
case POINTTYPE:
obj = create_point(state, lwgeom_as_lwpoint(lwgeom));
break;
case MULTIPOINTTYPE:
obj = create_multipoint(state, lwgeom_as_lwmpoint(lwgeom));
break;
case POLYGONTYPE:
obj = create_polygon(state, lwgeom_as_lwpoly(lwgeom));
break;
obj = create_multipolygon(state, lwgeom_as_lwmpoly(lwgeom));
break;
case LINETYPE:
obj = create_linestring(state, lwgeom_as_lwline(lwgeom));
break;
case MULTILINETYPE:
obj = create_multilinestring(state, lwgeom_as_lwmline(lwgeom));
break;
default:
snprintf(state->message, SHPDUMPERMSGLEN, _("Unknown WKB type (%d) for record %d"), lwgeom->type, state->currow);
SHPDestroyObject(obj);
/* Free both the original and geometries */
lwgeom_free(lwgeom);
@@ -2165,7 +2167,7 @@
/* If a geo column is present, generate the projection file */
if (state->geo_col_name)
- ret = projFileCreate(state);
+ ret = projFileCreate(state);
/* Close the DBF and SHP files */
if (state->dbf)
@@ -2202,16 +2204,16 @@
free(state->dbffieldnames[i]);
free(state->dbffieldnames);
if (state->dbffieldtypes)
free(state->dbffieldtypes);
if (state->pgfieldnames)
free(state->pgfieldnames);
/* Free any column map fieldnames if specified */
colmap_clean(&state->column_map);
/* Free other names */
if (state->table)
free(state->table);
@@ -2224,3 +2226,28 @@
free(state);
+ * quote_identifier()
+ * Properly double-quote a SQL identifier.
+ * Copied from PostgreSQL pg_upgrade/util.c
+char *
+quote_identifier(const char *s)
+ char *result = malloc(strlen(s) * 2 + 3);
+ char *r = result;
+ *r++ = '"';
+ while (*s)
+ if (*s == '"')
+ *r++ = *s;
+ *r++ = *s;
+ s++;
+ *r++ = '"';
+ *r++ = '\0';
+ return result;
Modified: trunk/loader/pgsql2shp-core.h
--- trunk/loader/pgsql2shp-core.h 2017-06-21 11:23:11 UTC (rev 15440)
+++ trunk/loader/pgsql2shp-core.h 2017-06-23 05:13:22 UTC (rev 15441)
@@ -23,10 +23,13 @@
#include <iconv.h>
#include "libpq-fe.h"
#include "shapefil.h"
#include "shpcommon.h"
#include "getopt.h"
#define P2S_RCSID "$Id$"
@@ -84,7 +87,7 @@
/* Name of the column map file if specified */
char *column_map_filename;
} SHPDUMPERCONFIG;
@@ -99,7 +102,7 @@
/* Database connection being used */
PGconn *conn;
/* Version of PostGIS being used */
int pgis_major_version;
@@ -132,10 +135,10 @@
/* PostgreSQL column lengths for all non-spatial fields */
int *pgfieldlens;
/* PostgreSQL column typmods for all non-spatial fields */
int *pgfieldtypmods;
/* Number of non-spatial fields in DBF output file */
int fieldcount;
@@ -199,3 +202,4 @@
int ShpLoaderGenerateShapeRow(SHPDUMPERSTATE *state);
int ShpDumperCloseTable(SHPDUMPERSTATE *state);
void ShpDumperDestroy(SHPDUMPERSTATE *state);
+char *quote_identifier(const char *s);
Modified: trunk/regress/dumper/realtable-pre.sql
--- trunk/regress/dumper/realtable-pre.sql 2017-06-21 11:23:11 UTC (rev 15440)
+++ trunk/regress/dumper/realtable-pre.sql 2017-06-23 05:13:22 UTC (rev 15441)
@@ -1,3 +1,3 @@
insert into spatial_ref_sys(srid,srtext) values (1,'fake["srs"],text');
-create table c (i int, g geometry);
-insert into c values (1,'SRID=1;POINT(0 0)');
+create table c (i int, g geometry, b boolean, """qColumn" varchar(20));
+insert into c values (1,'SRID=1;POINT(0 0)', true, 'quote test');
Modified: trunk/regress/dumper/realtable_expected.dbf
--- trunk/regress/dumper/realtable_expected.dbf 2017-06-21 11:23:11 UTC (rev 15440)
+++ trunk/regress/dumper/realtable_expected.dbf 2017-06-23 05:13:22 UTC (rev 15441)
@@ -1,2 +1,2 @@
-_ A I N
- 1
\ No newline at end of file
+_ ! I N B L "QCOLUMN C
+ 1 Tquote test
